Old 07-05-2013, 09:54 PM   #1
70c10stepper
Junior Member
70c10stepper's Avatar
70 c10 w/71 front suspension?
I need help from the experts on this site in identifying the suspension on my 70 c10. I believe it's '71? I'm leaning towards CPP's Grand Slam Kit & want to make sure everything will work on my frame.
Thanks in advance.
70c10stepper is offline   Reply With Quote
Old 07-05-2013, 11:08 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 70 c10 w/71 front suspension?
Hard to tell in this one picture.
Where are the hardlines and rubber brake hoses connected?
(In front or behind the crossmember?)
A-arms are definitely 67-72.
Better pics of the spindles?
Keith
Convert to disc brakes.
Old 07-05-2013, 11:10 PM   #3
lolife99
lolife99's Avatar
Only way to know for sure to to verify the spindle.
The upper balljoint and outer tie rod will be either a 71-72 or 73-87.
Pull the spindle and take it to your local auto parts store.
Verify what fits.
Rotors should be 1-1/4" wide.
Keith
Old 07-05-2013, 11:24 PM   #4
70c10stepper
Junior Member
Rotors are 1-1/4. Looks like they are located behind.
Old 07-05-2013, 11:30 PM   #5
lolife99
lolife99's Avatar
That means the crossmember is the original 67-70 style.
Most likely they just changed:
1) everything from the a-arms out
2) balljoints and spindles out (including the steering)
You still don't know for sure what year the spindles are.
Which doesn't matter if you are changing everything.
Buy 71-72 spindles and match EVERYTHING to them,...
or use 73-87 spindles and match EVERYTHING to them.
Keith
Old 07-05-2013, 11:36 PM   #6
70c10stepper
Junior Member
Lolife99,
More pics...
Old 07-05-2013, 11:45 PM   #7
70c10stepper
Junior Member
Thanks for you help.
That's what I needed to make sure of. This is my first resto & this site has great information.
Old 07-07-2013, 11:17 AM   #8
70c10stepper
Junior Member
If i use my stock 67-72 a-arms, the cpp grand slam kit should bolt right up?
Also, who's the member on here that everybody buys cpp parts from?
Old 09-11-2013, 06:26 PM   #9
belldar
belldar's Avatar
also interested where to get the parts for my 72 c15?
1988 1 ton 3+3 custom delux
Coming soon(stroked 496)
TH400, NP205
14 bolt rear, 60 front
4.56 gears, 6 inch lift
35inch dynapro MTs, pro comp 52 16x8 2.5 backspace
belldar is offline   Reply With Quote
Old 09-12-2013, 09:37 PM   #10
70c10stepper
Junior Member
Contact Justin at Scottshotrods as he can supply CPP components without all the headaches when you buy from CPP according to info on this forum.
I'm sure others will offer some opinions from their experiences.
Old 09-13-2013, 07:36 AM   #11
lolife99
lolife99's Avatar
I buy all my CPP parts from Summit Racing.
Usually in stock and ready to ship.
Keith
Old 09-13-2013, 11:03 AM   #12
70c10stepper
Junior Member
Do you know off the top of your head if Summit carries the Grand Slam Kits?
Old 09-13-2013, 11:23 AM   #13
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
I had no idea they carry CPP parts for these year model trucks.
What all does these kits include?
I'm going to have to do this to mine soon so just wondering.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-13-2013, 12:03 PM   #14
lolife99
lolife99's Avatar
They have all the individual components.
DO NOT,... I repeat DO NOT buy that stupid CPP kit that converts everything to 73-87 spindles.
That is such a waste for the 60-72 trucks.
Why change balljoints and tie rods if you don't have to?
Buy the correct spindle for your truck!
60-62
63-70
71-72
Simple.
Keith
Old 09-13-2013, 12:08 PM   #15
lolife99
lolife99's Avatar
Here's a discription of the 60-66 kit:
Grand Slam Complete Suspension Kit w/ Front Disc Brake Conversion - 63-66 Chevy PU
This kit includes stock or 2.5" dropped front spindles, bearings, loaded calipers, 12" rotors, brake hoses, master cylinder, power booster, proportioning valve, four gas shocks, four lowered coil springs, inner and outer tie rod ends, custom adjusting sleeves, upper and lower ball joints, seals, spindle nuts, dust shields and dust caps. All necessary hardware is included. Select how much you want to drop the truck, and we'll send you the right coil springs to make it happen. Disc Brakes require at a least a 15" wheel and may not work with some factory drum brake wheels.
Factory 6-lug applications have 7/16" dia. studs and 5 on 5-lug kits have 1/2" dia. studs.
Notice it has you changing balljoints and tie rods?
Why?
Because you are now using 73-87 spindles.
Must be more mark-up on 73-87 parts.
Keith
Old 09-13-2013, 12:13 PM   #16
lolife99
lolife99's Avatar
Personally,... (again, just my opinion),... I would buy the correct year drop spindle, drop springs, and drop shocks from wherever (Summit, ECE, McGaughy's, Western Chassis) then buy your 5 lug rotors, calipers, bearings from your local Auto Parts store.
Use a 71-72 M/C.
I DO however like to use aftermarket aluminum M/C now along with an disc/drum prop valve OR,... an adjustable prop valve.
ECE sells conversion brake lines along with companies like Performance Online.
Back on subject,... shop around at Summit racing.
They have a complete line of CPP products.
Keith
Old 09-13-2013, 06:47 PM   #17
70c10stepper
Junior Member
Old 09-13-2013, 06:52 PM   #18
70c10stepper
Junior Member
Lowlife99, what about the modular spindle kit from CPP?
Old 09-13-2013, 07:58 PM   #19
lolife99
lolife99's Avatar
Summit should have it all.
Take your CPP part number to Summit Racing's website.
Again,... that is where I shop.
Some board Vendors may match or beat their price.
I just wanted to tell all the members to shop around for the best price and the best customer service!
Keith
Old 09-13-2013, 08:21 PM   #20
70c10stepper
Junior Member
Thanks.
Old 09-14-2013, 09:41 AM   #21
70c10stepper
Junior Member
Anybody want to offer their experience w/modular spindle from CPP and the complete kit using the modular spindle?
Also where you purchased?
Old 09-16-2013, 12:41 PM   #22
C20-67_N_MO
Question Re: 70 c10 w/71 front suspension?
Use a 71-72 M/C.
Sorry 70c10stepper, just need to ask the resident expert about this.
But if I wanted to convert my 6-lug front suspension drum brakes to a drop spindle and disc brakes I would want what?
Old 09-16-2013, 03:03 PM   #23
lolife99
lolife99's Avatar
I would say,... the same stuff that the 5-lug guys are running.
The only exception is you use an aftermarket 6-lug rotor.
I got my 6-lug rotors on my red '69 from Early Classic Enterprises.
They work perfect with an HD drop spindle (designed for 1.25" width rotors).
Keith
Thread Tools
Display Modes
