Old 07-08-2013, 10:43 AM   #1
jsdoyle
jsdoyle's Avatar
Heater Cutoff?
Now that summer is here I have my heater turned off at the controls on the dash but I'm still getting a fair amount of heat coming through the vent under the dash. I thought with the flap closed by the core I would be able to open the vent and get some cooler air to pass through into the cabin.
Any ideas on the best way to stop it? Should I install a valve on the heater hoses?
Or, is the flap just stuck? It sure acts closed from the position of the arm connected to the cable.
Thanks!
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 07-08-2013, 01:05 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Heater Cutoff?
Put a valve on in and out at the heater hose under the hood, most of us do this so the AC can run optimally.
http://www.autozone.com/autozone/par...alve/_/N-91sh0
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-08-2013, 02:41 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Heater Cutoff?
Which one of those do you recommend?
66 C20 Service Truck:
Old 07-08-2013, 02:45 PM   #4
jsdoyle
jsdoyle's Avatar
Re: Heater Cutoff?
I just ordered 2 "FOUR SEASONS 84707 Heater Control Valve" off ebay
Payed 9 dollars for one and 11 for the other. Free shipping. Should take about 10 minutes to put in this weekend!
Thanks for the tip!
Scott
Old 07-08-2013, 03:54 PM   #5
argonaut
argonaut's Avatar
Re: Heater Cutoff?
I used one like this on the 5/8" feed hose: http://www.ebay.com/itm/New-GMC-Ford...-/350585704301
I got a long cable and mounted it to the "Heat" lever on my deluxe heater controls. So now the lever not only closes and opens the air flap, but also closes and opens the fluid valve at the same time.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-08-2013, 05:02 PM   #6
Wrenchbender Ret
Re: Heater Cutoff?
I always use the one Argo shows. You can hook a cable to it or turn it manually.
Wrenchbender Ret is offline   Reply With Quote
Old 07-08-2013, 05:08 PM   #7
LostMy65
LostMy65's Avatar
Re: Heater Cutoff?
What happens when the water pump tries to push water through that hose? Doesn't closing that hose create back pressure on the water pump?
Old 07-08-2013, 05:29 PM   #8
Rufton
Re: Heater Cutoff?
Thanks for the tip!
Scott
I tried two valves that looked like picture; Murrey from Oreilly FWIR. They both leaked past the packing. I have since used ball valves from home improvement store and they have worked perfect for a few years now.
Rufton is offline   Reply With Quote
Old 07-08-2013, 05:39 PM   #9
Rufton
Re: Heater Cutoff?
Pic of ball valve (lower left w/ red handle).
Nipple available at some auto parts stores.
Old 07-08-2013, 07:31 PM   #10
luvbowties
luvbowties's Avatar
Smile Re: Heater Cutoff?
Hey Clyde, just noticed u suggested using 2--one on each hose. Just for info that I lack, why both? (...or is that only for the fortunate few members who also have fuel-injection??!!)
Thanks for the help, and still hoping for F-I, some day, on my '66 with stock, yet carb'd, vortec.
Sam
luvbowties is offline   Reply With Quote
Thread Tools
Display Modes
