Old 07-10-2013, 08:37 AM   #1
86c20
86c20's Avatar
txv in ac where?
ok guys so i am trying to gett the ac in my k30 going it has never worked before so i am shooting in the dark here. i put some 134 in it as it has been changed over at some point cpmp came on had about 35 on the low side but i noticed that the bottom of the condenser was freezing up to the high pressure port. so i am thinking that the txv is gummed up maybe?? when i got thte truck the owner was dicking with the ac and i dont know what he did at all. and it does not even start to cool off at all. any suggestions?
also if i need to change out the txv what one do i put in? and does anyone konw a part number for the right evap for 134 in these trucks?
thanks guys, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 07-10-2013, 08:45 AM   #2
hyatt
Re: txv in ac where?
not sure what year you are working on but on 80s and 90s truck there is a orrifice valve in hi pressure line of evaporator that if clogs will cause the freeze up you are talking about Remove the line and use needlenose pliers to remove it and replace Flush all lines out while you have it open
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 07-10-2013, 06:09 PM   #3
86c20
86c20's Avatar
ok what should be used as a flush?
Old 07-10-2013, 07:11 PM   #4
hyatt
There is a comercial flush available but I just used air pressure Did ac work for 23 years I would replace accumulator while you had system open
1946 car hauler
1948 surburban
1937 chevy sedan
1967 ss396 chevelle
Old 07-10-2013, 10:34 PM   #5
hatzie
Moderator
hatzie's Avatar
Flush it out with a commercial flush. If you get a sludgy mess from the condenser, evaporator, or lines you'll want to re-think how much you need the AC.
Badly done 134 conversions can make a mess of the AC system internally.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-10-2013, 10:59 PM   #6
86c20
86c20's Avatar
i think this one was done ok as i think the comp has been changed to one only for 134
also looking at the orifice tubes what is the deal with them? diff size and one that is variable?? hows this i want as cold as i can get. and the money is not the problem it is just the time to get it there lol. i am going to pump it down and check the line and the ot and see whats going on in there. i am surpised tho that is not leaking yet. as i had some one pump it down to check and they said it had a big leak so idk about that
Old 07-12-2013, 10:23 AM   #7
hatzie
Moderator
hatzie's Avatar
Get the variable valve. It's supposed to make the system more R134 friendly.
If you're really ambitious change out the tube and fin condenser for a high efficiency unit... I believe they are called parallel flow condensers. They make a HUGE difference in cooling and head pressure.
Old 07-14-2013, 11:51 AM   #8
86c20
86c20's Avatar
ok so i put in the new orifice fushed it out and charged it up. this is where i stand.
low side. 40-50
high side is at 150 and floats some about 5 pis
and i am geting about a 40* drop across the condenser. dont seem like enough.
out of the pump is in the 175 area and out of the condenser is 140ish little lower.
HELP haha
Old 07-14-2013, 01:45 PM   #9
86c20
86c20's Avatar
ok got a correction to make. its 55on the low 140 on the high with 48* outthe vents witch i thought was oddas it was not all that cold. took it for a drive and got an instant 38* out the vents at about 15mph and it got even colder as i drove.
does this seem some what right to you guys?
Thread Tools
Display Modes
