70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Rear Axle U Bolt
I am going to be doing a complete drum to drum rear end swap ( 3:73 single to 3:08 Posi ) and looking at what is involved i am wondering if anyone sells the u-joint clamp thing that holds the axle to the trailing arm. Maybe the bolts will come off and maybe they wont and if they break I'd like to have new ones sitting ready to use if needed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Old Skool Club
![]() Join Date: Jun 2001
Re: Rear Axle U Bolt
Greg, I had new ones made at a truck shop that does suspension repair. My originals weren't too bad, but they were rusty and I just thought that new would be good. I tried NAPA but opted to not order them from LMC or such.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#3 | |
The Older Generation
They are called "U" bolts. When you get the nuts off they should slide out through the plate and trailing arms if they are not rusted tight. You might have to heat the nuts to get them off. As Ray said, any good spring shop should be able to make them for you. If you can't find a spring shop go ask a garage that works on bigger trucks where they get theirs done. LockDoc
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
This member can probably help you out. I got mine in just a few days. Posted via Mobile Device
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
Thread Tools | |
Display Modes | |
