Old 07-12-2013, 06:43 PM   #1
1972RedNeck
1972RedNeck's Avatar
350 to 292
I would like to stick a 292 in my '72 K20. One of the motor mounts is in the correct location, right? The other has to be moved? Are 350 and 292 frame brackets the same? The cross member is different.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-12-2013, 06:54 PM   #2
sanford&daughter
sanford&daughter's Avatar
Re: 350 to 292
Frame brackets are different and the 6 uses the rear holes in the frame I believe
sanford&daughter is offline   Reply With Quote
Old 07-12-2013, 07:35 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 350 to 292
I know the K/10s required a diagonal-running x-mbr under the 292 L6 [only]. Not sure about the K/20s and 30s.
I have one I'm saving for a 292 K/5 project, but I'll shoot you a pic if needed.
I think the L6 towers are different. The 292 uses a different passenger side tower than the 250. The drivers side tower is the same I'm told. [Never ran a 250 L6.]
Old 07-12-2013, 11:13 PM   #4
1972RedNeck
Re: 350 to 292
So the frame towers are different, huh? Anybody have a cross member and towers they want to trade for my SBC ones?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-12-2013, 11:14 PM   #5
pritch
pritch's Avatar
Re: 350 to 292
X2. I'm pretty sure they all (K10, K20 & on up) had that funky cross member. I believe it's one of the most specific parts on these trucks. If you want a 292 in a 4X4, your gonna need one. And I further believe that the motor mount towers are different between the 4WD and 2WD, and the mounts themselves are more like the clam shell style.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 07-13-2013, 12:42 AM   #6
franken
Re: 350 to 292
Hold up...
350 to 292?
Probably not a great idea.
The GM 350 is probably the most common engine in the world. Being common, means parts are cheap.
Nothing wrong with the 292, but why swim upstream?
franken is offline   Reply With Quote
Old 07-13-2013, 08:32 AM   #7
1972RedNeck
Re: 350 to 292
4.125" stroke, 7 main bearings, roomier engine compartment, less common, harder to build and everyone knows that 6 is greater than 8.
It's always easier to shoot things floating downstream than swimming upstream.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-13-2013, 07:31 PM   #8
'68OrangeSunshine
Re: 350 to 292
If a 292 costs twice as much to build as a 350, you're still ahead since it will last three times as long. I've been running 292s in my C/10 for only 40 years now, so I'm talking from experience not theory. I can't say how many V8s I've lunched.
The 292 is about 120 Lbs lighter than the SBC.
The 292 has deep growling torque -- perfect for a 4x4.
The 292 tolerates desert heat much better than a V8.
The only reason GM dealers didn't like to option the 292, was the crossmember issue, I figure.
Dealers had a hard sell approach pushing the 350 and the automatic tranny, back in the day.
I may have a pic of the X-mbr in my files. But I'll have to search and post later.
Old 07-13-2013, 07:53 PM   #9
'68OrangeSunshine
Re: 350 to 292
Here you go. Some pix of the 292-Only K/ Series crossmember. The towers are the same for the C/ and K/ Series, I think. I will have to dig that part out of the back of the Suburban [parts locker] and match it to the one on the C/10 Stepside.
Old 07-13-2013, 07:56 PM   #10
1972RedNeck
Re: 350 to 292
Where could I find one? I've called around to all the yards and no one has any.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-13-2013, 08:53 PM   #11
pritch
pritch's Avatar
Re: 350 to 292
Your looking for 20 pounds of pure Unobtainium. You need to find a K series that still has the 292 in it. A tall order, since anyone with any sense at all hacked that sucker outta there 30 years ago so they install the "normal" cross brace so they could drop in a 350 and be, you know, common.
'68 Panel
'68 C-10
Ol' Green
Old 07-13-2013, 09:00 PM   #12
pritch
pritch's Avatar
Re: 350 to 292
Naw, the towers are different, too, between the C & K. See, I found a 69 K with a 292 in a yard a few years ago and I took the motor and the towers. I found out that those towers are completely different. After some research, I discovered how rare that X member is, I went back and got it so I can build a 292 4X4, too.
'68 Panel
'68 C-10
Ol' Green
Old 07-13-2013, 09:05 PM   #13
71sixgun
Talking Re: 350 to 292
I like it!
71sixgun is offline   Reply With Quote
Old 07-13-2013, 09:44 PM   #14
1972RedNeck
Re: 350 to 292
Does the 292 use the same insulators as a 350?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-15-2013, 10:27 PM   #15
'68OrangeSunshine
Re: 350 to 292
Yes.
Thread Tools
Display Modes
