Old 07-13-2013, 09:47 AM   #1
nascarguy320
nascarguy320's Avatar
69 C20 front end ?
I have a 69 c20 with drum brakes on the front, I want to keep the 8 lugs on it but i want to lower it and put disc on it so what is the best way to do this...
nascarguy320 is offline   Reply With Quote
Old 07-13-2013, 10:03 AM   #2
briank
Re: 69 C20 front end ?
I believe 71 was first year for disc, too bad because I junked my 71 c20 frame with everything. Not sure on lowering though.
briank is offline   Reply With Quote
Old 07-13-2013, 04:35 PM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
Go out and buy New drop spindles for a 3/4 ton truck and get all the disk brake parts and poprtioning valve is very important
stsalvage is offline   Reply With Quote
Old 07-13-2013, 06:13 PM   #4
treveiger
treveiger's Avatar
Take a look at this.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
You'll also need a c20 master cilynder from a 71 or 72 and a porportioning valve. If you'd like I can describe my set up with what I have for my 69c20.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 07-13-2013, 09:05 PM   #5
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I did an 8-lug disc brake conversion on my 69 C20 last year. I was not sure what way to go. I was undecided between a CPP kit or Performance Online (POL). I decided to go with the POL kit. CPP makes a good product, but I heard many negative comments on this forum about their customer service. I was very pleased with the POL kit.
Or you could find an 8 lug square body truck and swap out the complete front suspension/brakes/engine crossmember. Not many bolts to remove the crossmember from the frame. You roll out the drum setup and then roll in the disc setup. You now have disc brakes and the higher quality ball joints. I figured if I did that I would have to replace some stuff on it anyway so I went with the new kit. Sorry I don't have pictures of it completed. I should take some.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-14-2013, 10:41 AM   #6
nascarguy320
So is 71-72 8 lug trucks are the only parts i can use if i dont change the front cross member out for spindles.I have only had the truck now for 3 weeks and very new to these trucks...
Old 07-14-2013, 11:35 AM   #7
treveiger
treveiger's Avatar
The guy that owned my truck before me swapped it out to disks from a mid 80s c20 but kept the old a arms. I'm assuming he switched ball joint and spindles from the newer truck but I'm not sure.
Thread Tools
Display Modes
