07-15-2013, 02:21 AM | #1 |
Glen
Weatherstrip and window channel kits
Where's a good place to get a full kit for my 70 Suburban?
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
07-16-2013, 01:50 AM | #2 |
Re: Weatherstrip and window channel kits
I am accumulating all of the rubber pieces to completely replace all in my burb. Here's what I have learned: Most single vendor will not have all of the pieces. I got the rear barn door window glass and hinge seals from Steele's. I actually got all of the roll up window and door gasket seals from LMC. Still need to source the windshield gasket, rear sides and 1/4 window gaskets. I will probably get them from brothers or steele's as they are the only source for them I have found. The rear side window gaskets are very spendy! I hear that precision rubber www.prp.com are very good replacement pieces.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
07-16-2013, 12:19 PM | #3 |
Junior Member
interested as well
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
07-16-2013, 01:16 PM | #4 |
Glen
I'm also noticing its hard to find everything from one place too JB. I just noticed LMC has exterior rubber for the 3rd door and a whole page for the rear door components and rubber.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=18 I'm assuming the 4 pieces shown in the window seal kit (11) covers both driver and passenger. $75 isn't cheap. Anyone else carry good quality seals for better prices?
Past Trucks
07-16-2013, 01:42 PM | #5 |
Steele's rear side window gasket are $217, at brothers $180. The little rear door hinge grommets are 40 bux in most places. I think brothers was the only place i could find the 1/4 window seals. Nobody repops the rear sill plate, bit i have found several vendors for the third door sill plate.
JB Posted via Mobile Device
07-16-2013, 08:14 PM | #6 |
BlahBlahBlah
How bout supporting our board vendors? ... I got all the stuff for my panel from Wes at Classic Heartbeat and Frank of PICKMUPS. Both board members and they have a lot of burb and panel stuff.
There are other board vendors too that you can source ... http://67-72chevytrucks.com/vboard/showgroups.php ... scroll down to gold vendors and below them are the platinum vendors. These guys pay most of the bill to keep this place running!
07-17-2013, 01:07 PM | #7 |
Glen
Hey CG, I'd gladly look to some supporting vendors. That link has a lot of people listed and sifting through each one is not real efficient. Besides the ads that pop up on top, are there an others way to find out about the vendors businesses?
Past Trucks
07-17-2013, 03:11 PM | #8 |
You'll find all the suburban seals on our web site here
http://www.gmcpauls.com/Suburban_-_Panel.htm and here http://www.gmcpauls.com/suburban_-_panel_2.htm Paul @ GMCPauls |
07-17-2013, 03:33 PM | #9 | |
Junior Member
07-17-2013, 03:43 PM | #10 |
The door seals are glue on version, we only offer the push on style for the trucks as I do not like the way the push on version bunch up at the 90 degree bends found on the suburban door openings. On a side note I've taken a set that I used for my own suburban to a rubber company that used to be in Indianapolis and had them cut up 3 of the push on door opening seals based on the measurements of the door opening frames they gave them 45 degree angles at the cuts and then they Vulcanized ( I believe that's the way what they said would be spelled ) back together so they were 1piece again and installed them on 1 suburban I had. Cost was around $80.00 for them to do all 3 pieces.
So if you really want glue less that is a option to see if you have someone local that can do it. Paul @ GMCPauls |
07-18-2013, 01:24 AM | #11 | |
Glen
Past Trucks
07-19-2013, 05:19 PM | #12 |
Any hints on how to remove the stainless "keeper" from an existing windshield (custom Suburban)or am I better to not re-use the old rubber . the glass needs replacement. The side windows will be removed for painting (I hate masking lines on rubber). Same thing here , am I better to just cut the old ones to remove the glass or should I try and salvage them?
Thanks for your help. |
07-19-2013, 05:47 PM | #13 | |
That's just my take on it, seen posts where guys have done it all no problem too. Paul @ GMCPauls Paul @ GMCPauls |
07-23-2013, 01:48 PM | #14 | |
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-24-2013, 02:31 PM | #15 | |
http://www.gmcpauls.com/Suburban_-_Panel.htm Part # 132068 $74.00 for the pair. Paul @ GMCPauls |
07-24-2013, 03:04 PM | #16 | |
R/
07-24-2013, 03:22 PM | #17 | |
The seals your asking about GM referred to as the fixed vent seals which is what I also named them on our web site. They are on the same Suburban weatherstrip page Suburban Rear Fixed Vent Window Seals, sold in pairs part # 1287374 $34.95 for the pair. Paul @ GMCPauls |
Thread Tools | |
Display Modes | |
