07-15-2013, 06:05 PM | #1 |
Anyone Running the A-833 MY6 GM manual 4 Speed Overdrive
Took me about 4 years to finally find a complete, bell housing, tranny & Hurst shifter, A-833 4 speed overdrive for my '72 C10. Logged 370 miles on my '72 truck to go get this thing a week ago. These things are hard to come across or have been for me to find. Now I just need to find a 67-72 C10 high-hump center floor piece & a cross member. Anyone else running one of these, should be a good addition for my driver. These are close enough to a 700R4 but you get the fun of the manual.
700R4 - 3.06/1.63/1.00/0.70 A833 O/D - 3.09/1.76/1.00/0.73 |
07-15-2013, 06:20 PM | #2 |
Re: Anyone Running the A-833 MY6 GM manual 4 Speed Overdrive
Nice find, in my book rowing your own gears is the most fun! It's a truck not a taxi cab.
07-15-2013, 06:31 PM | #3 |
I just looked that thing up cause I never heard of them before. What kind of truck did it come from to have a bell housing that will bolt up to a Chevy?
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
07-15-2013, 07:15 PM | #4 |
81-85 or so, it was a COPO option that's kind of hard to come across.
Posted via Mobile Device |
07-15-2013, 07:32 PM | #5 |
Member Keith Seymore has a factory original.
His contact. http://67-72chevytrucks.com/vboard/member.php?u=56854 I hope you got bucket seats. THat shifter sits back quite aways! |
07-15-2013, 08:00 PM | #6 |
07-15-2013, 08:09 PM | #7 | |
I have a removable transmission hump, though the hole is at the front of it. And I most likely have a cross member. I have several post in the for sale area. One is 72 longhorn parting out and the other is transmission humps ...
07-15-2013, 08:51 PM | #8 |
i have the same transmission.But i have no shifter.how did you locate yours,i too have had no luck..no one has info on this other than it is a 4 speed.
07-15-2013, 08:55 PM | #9 |
thers one here for sale for $150
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress |
07-15-2013, 09:22 PM | #10 |
07-15-2013, 09:37 PM | #11 |
You have the complete set; NICE! I have one of these behind my GMC V-6.
Here are some reference articles: http://www.classicjunkyard.com/new_process_a833.htm http://www.customclassictrucks.com/t...n/viewall.html
MusicMan70 1961 GMC Suburban |
07-15-2013, 09:59 PM | #12 |
go cyclones
Looks pretty cool
07-15-2013, 11:11 PM | #13 |
You know grancuda I don't think you'll need a high hump to fit that tranny in there. It's no taller than a 3 or 4 speed muncie.
As for using the bench seat shifter you might need to build an extension to make it work or you could do like they did in the 64-65 Nova's and make a notch in your seat. |
07-16-2013, 07:02 AM | #14 |
a-833 sounds familiar...was that normally a mopar trans?
1970 short step c10 leaf spring 454 |
07-16-2013, 07:33 AM | #15 | |
Yeah, I am not sure how the shifter is going to work out yet. I will make all adjustments in the handle and not modify the seat. Also, my motor is in the 6cyl position so it is set back even more than a regular V8 truck. Yes |
07-16-2013, 06:09 PM | #16 |
Got one, love it. Used a stock auto tranny crossmember and the factory mount holes. The BBC also uses the factory location frame holes. If you need overhaul parts a shop in Las Vegas http://www.drivetrain.com/parts_cata...rhaul_kit.html sells various kits. There are also good sources of info on the net about them. I think it was Super Chevy that has a good rebuild article online. While I too wanted the Hurst logo shifter in mine, But the fit and feel of the factory shifter is spot on for me. Maybe I'll cut one up and have it rechromed sometime.
07-16-2013, 11:19 PM | #17 |
I have a radical idea!
I have one that is going a factory 3 speed truck. With decent rearend gears, they are pretty fun trannys. Mine came out of an '81 GMC.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-17-2013, 01:45 AM | #18 |
Volksworld is correct. The A-833 is the same code Chrysler used for transmissions used in the cars they built. The Chevrolet uses the Chrysler transmission. It is really neat the way they made it overdrive. If you notice the pictures from Dcarey, the 3 & 4 shift lever puts the rod down instead of up. The unsuspecting driver then shifts 1, 2, 4, 3. They only needed 2 special parts to make the overdrive. The cluster gear has a very large 3rd gear on it and the 3rd speed gear is very small, making 3rd gear overdrive. So the shift sequence is: low, 2nd, 4th ( direct ), then 3rd ( overdrive ). Ford did the same trick with their top loader. If you ever see a Ford top loader for sale CHEAP, look for the 3-4 lever to be upside down. That is used in pickups, like GM, but not cars. Roy
07-17-2013, 01:49 AM | #19 |
Oops, I didn't credit the pictures correctly. Sorry, Grancuda!
09-25-2013, 09:25 PM | #20 |
So I have got mixed info on the length, is the MY-6 the same length as a Saginaw 3 speed?
09-25-2013, 09:35 PM | #21 |
I thought of trying this but ended up with the stuff to go with the Camaro/S-10 T-5 hybrid trans. I too have gotten a high hump tunnel for mine and I know for sure that is not needed. Mine was a three on the tree so I took a van colum and filled the holes where the shifter pointer was and ground off the boss for the shifter and filled it all in real nice and then primed it all. It is all slick now so it looks like a factory floor shift tilt. Good luck with your conversion. Jim
09-25-2013, 10:02 PM | #22 |
Yes, they are both 21" overall length without the bellhousing.
09-25-2013, 10:16 PM | #23 |
Mine is the even rarer version that has the standard GM flange. Mine will bolt to any standard GM bellhousing.
01-10-2021, 08:52 AM | #24 |
I hate to wakeup the dead thread, but how did this turn out? Mine has been on the shop floor for 3 years now and it finally asked to go in the truck.
Thread Tools | |
Display Modes | |
