Old 07-17-2013, 08:58 PM   #1
McCoyAZ
McCoyAZ's Avatar
6 lug to 5 lug.....'64 C10
So instead of swapping out a complete rear differential I decided to just pull the axels and weld up the old 6 lug configuration and have the axels re drilled to a 5 on 5 bolt pattern.
What I would like to know is:
Since I am pulling the axels, I assume I should replace the axel bearings and seals and want to know what else I should look at changing while I have this all apart?
New 5 lug drums, new brake pads, replaced the rear brake cylinders.....
anything else need to be addressed??
McCoyAZ is offline   Reply With Quote
Old 07-18-2013, 04:22 PM   #2
poorboy
poorboy's Avatar
Re: 6 lug to 5 lug.....'64 C10
You can get conversion axles.
http://www.speedwaymotors.com/1963-6...Kit,46254.html
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 07-18-2013, 05:51 PM   #3
McCoyAZ
McCoyAZ's Avatar
A guy would have to be a total moron to spend $500 on that kit when he can do the conversion for about $180 with new drums, re drilling the axels and changing the bearings.
Old 07-18-2013, 10:13 PM   #4
poorboy
poorboy's Avatar
I wouldn't buy them. I'm too cheap for that hence my username. I was just throwing it out there that they were available.
Old 07-19-2013, 08:29 AM   #5
Indian113
Indian113's Avatar
Couldn't you also redrill the drums when you drill axles?
Indian113 is offline   Reply With Quote
Old 08-03-2013, 10:42 PM   #6
McCoyAZ
McCoyAZ's Avatar
Well got the axels re-drilled, new brake drums off a '72 for the 5 lug, new bearings, new seals and c clips. Total investment about $200.00
I will caution anyone considering having this done that they check the machine shops work prior to leaving their shop, something I did not do.
Found out after I had everything almost put back together that they did not mill the center of the axel down quite far enough to fit the drums I had and it was a PITA to die grind the center out of the drum but I got it to fit after an hour of messing with it.
I am not a mechanic and this wasn't that hard to do.
Thread Tools
Display Modes
