Old 07-18-2013, 07:58 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
How to "clean" an Aluminum Intake?
I'm about to tear into my engine bay to install a serpentine belt set-up and I would like to do a little clean-up on the Edelbrock manifold already in place. Any suggestion how to get some of the oil stains off the surface? I'm thinking I might shoot some "brake-clean" on it or maybe some "Dawn and white vinegar mix". Any other tips? Thanks for your thoughts.
TobyArnot is offline   Reply With Quote
Old 07-18-2013, 09:48 AM   #2
Fldawg
Fldawg's Avatar
Re: How to "clean" an Aluminum Intake?
if you can get your hands on some simple green aircraft cleaner that stuff works great, i cleaned my engine after the truck came from the paint shop and it did't hurt the new paint. just spayed it on and hosed it off
Fldawg is offline   Reply With Quote
Old 07-18-2013, 11:16 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
purple power simple green.
Or some aluminum cleaner even. I would clear it or paint it afterwards though
John
1999 Toyota Tacoma 4x4
Old 07-18-2013, 11:41 AM   #4
trucks72
trucks72
trucks72's Avatar
Sand blast them with baking soda. Doesnot eat into them. Makes the look like new.
trucks72 is offline   Reply With Quote
Old 07-18-2013, 12:43 PM   #5
TobyArnot
TobyArnot's Avatar
I've found some Simple Green Aircraft cleaner on line and it's on the way.
Sand blast them with baking soda. Does not eat into them. Makes the look like new
I'm not going to pull the intake, so blasting is not an option.
Thanks guys for the input!
Old 07-18-2013, 12:54 PM   #6
72 Sierra
I just did this..Got some purple power degreaser and mothers aluminum mag cleaner.also some wire detail brushes.from auto zone. clean with degreaser first then mothers cleaner.use detail brushes to get off stubborn stuff.also a lot of towels you will need them.turned out good.my intake was on the motor to.
72 Sierra is offline   Reply With Quote
Old 07-18-2013, 01:46 PM   #7
Madtat
Madtat's Avatar
Originally Posted by trucks72 View Post
sand blast them with baking soda. Doesnot eat into them. Makes the look like new.
^^^x2
Madtat is offline   Reply With Quote
Old 07-18-2013, 02:03 PM   #8
Daubs
Daubs's Avatar
Previous owner painted my Edelbrock Aluminum intake. I wire wheeled it, then cleaned up with thinner...then sprayed aluminum rattle can engine paint. It's held up well for 4+ years.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 07-18-2013, 02:08 PM   #9
Daner
Daner's Avatar
If you ever take it off a pressure washer with a boiler on it works great.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 07-18-2013, 02:19 PM   #10
StingRay
StingRay's Avatar
Blast with glass bead if you have it off. It will look like it came out of the box.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-18-2013, 06:07 PM   #11
Fldawg
Fldawg's Avatar
don't mean to step on toes but most intakes I've seen cleared turn yellow and it doesn't take long
Old 07-18-2013, 06:33 PM   #12
Rufton
I don't like clear either. If intake has a hint of a leak I'd pull and media blast w/ glass bead (as mentioned). I've tried acid bright, etc. but not muck luck. Glass bead was fast and easy except you may need better excuse to pull it. Does anyone have pics of Aluminum cleaned w/ chemical?
Below is pic of stained intake after glass bead blast.
Rufton is offline   Reply With Quote
Old 07-18-2013, 06:46 PM   #13
Tinkermc
Glass bead blast cabinet will leave it like brank new.
Tinkermc is offline   Reply With Quote
Old 07-18-2013, 07:05 PM   #14
GRX
GRX's Avatar
Remember, cast aluminum is porous. If the intake was installed bare (no paint etc) and is really greasy & oily you had better be darn sure you get ALL of that out of the metal or you'll be hard pressed to get paint to stick for any amount of time. De-greasing & glass beading is a good start. Then bake in an oven to remove all moisture. Paint with hi-temp of your choice, let dry for a short time, then cure in a 450 degree oven for 6 hours so the paint can "soak in" as it were. I have done many intakes that way. The Edelbrock on my GTO still looks great over 20 years later.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-18-2013, 07:06 PM   #15
gotchamel
Zep makes a product for aluminium called Zepalume.I have used it alot just not on an intake manifold.It is an acid based cleaner.
gotchamel is offline   Reply With Quote
Old 07-19-2013, 09:45 AM   #16
Powdercoat with stainless exhaust coating and forget about it.
Old 07-19-2013, 11:16 AM   #17
oldblue1968chevy
Not stepping on toes here. I just know that if gas leaks on it it stains and almost soaks in
John
Old 07-19-2013, 11:45 AM   #18
Rufton
Stains the powder coat also?
Old 07-19-2013, 01:57 PM   #19
solidaxel
solidaxel's Avatar
Watching this one !
Watch the brake clean around rubber seals!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-19-2013, 06:18 PM   #20
74baggedbug
Just got some simple green extreme aircraft cleaner but won't be able to try it till Sunday evening when I get off work.. Ill let you know the results
74baggedbug is offline   Reply With Quote
Old 07-20-2013, 09:06 AM   #21
How does cast wheel cleaner work? How about vinegar?
Old 07-20-2013, 09:57 AM   #22
skorpioskorpio
A good trick from the bike restorer world where lots of the exposed bits are cast aluminum. get a big bucket of Pine-sol and let it soak for a couple days, it will take all the staining out. I does not remove any corrosion, but it does lift those stains that soak in out.
skorpioskorpio is offline   Reply With Quote
Thread Tools
Display Modes
