Old 07-19-2013, 09:45 PM   #1
Dachdu69C10
Dachdu69C10's Avatar
Low tail light voltage and no lights
Hey guys I'm having issues with my tail lights, I made a new harness from the firewall to the lights themselves, I have 10v with the brakes applied at the firewall connector, and it goes from 10v to 3v with the blinkers on. All the wiring is done the way it would have been factory. And each brake light has a ground from the housing to the underside of the bed. I also have 10v at the bulb sockets and new bulbs but no light at all. Any suggestions?
Dallas
1969 C10 custom 1/2ton "Project"
2004 Volkswagen Jetta DD
"On the internet Men are Men, Women are Men, and little Girls are FBI Agents"
Dachdu69C10 is offline   Reply With Quote
Old 07-19-2013, 09:54 PM   #2
cdowns
cdowns's Avatar
Re: Low tail light voltage and no lights
run a ground wire from the bed to the frame to complete the circuit
Old 07-19-2013, 10:01 PM   #3
chvtrkman
chvtrkman's Avatar
Yup,what cdowns said...I had the same problem and it turned out the ground was bad. Ran a new ground wire directly to frame and problem solved.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 07-19-2013, 10:13 PM   #4
CastIron
CastIron's Avatar
I bet that if you measure voltage at your ground wires you'd have 10 volts there too. A system that was working properly should have zero volts after the bulb.
CastIron is offline   Reply With Quote
Old 07-20-2013, 01:37 AM   #5
Dachdu69C10
I ran a big 4 gauge ground from the chassis to the cab, and re ran the grounds from the housings to the frame. They are working better then ever thanks for the advice guys.
Dallas
Old 07-23-2013, 07:20 AM   #6
Square_78
Square_78's Avatar
I've got the exact same prob. I went to install LED tail lights and they don't light up. Tested the voltage at the tail light socket and its like 9 volts. Not enough to trigger the LEDs. I am going to make a good ground strap and hopefully it makes a difference. Good info guys thanks
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Thread Tools
Display Modes
