Old 07-19-2013, 11:42 PM   #1
hart11b
hart11b's Avatar
SPID Help
I'm hoping someone can help me out with some SPID codes. I need help with the fourth down on the left column (4P...) and the top right code. This is a 1969 C20 that doesn't have a lot of options. Also, the engine is the original V8. Anyone know the base engine for the '69 C20?
hart11b is offline   Reply With Quote
Old 07-20-2013, 08:27 AM   #2
Re: SPID Help
250-6 is the base engine if your VIN is CS1 and it's a 307 if VIN is CE2. The important digits in the RPO codes are the letter and two numbers thay follow. I can only make out the "P",so the only codes I know of that would apply to this truck are the P13- Side mount spare tire carrier,P10- EQ Tire Carrier ,or P03- Chrome hubcaps. The side mount would be (or the holes) on the driver side ahead of the wheel house. It very well could have been the hubcaps since painted caps would have been standard
Old 07-20-2013, 03:59 PM   #3
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: SPID Help
I think the top right one is for the below eyeline mirrors
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-20-2013, 07:24 PM   #4
SS Tim
SS Tim's Avatar
Re: SPID Help
Well here is my best guess based on the pictures in post #1.
Without knowing the assembly plant it is a little hard to nail down the exact verbage as it varied between plant and years. If you want more P/M for an email address to send me a better SPID picture and full VIN.
Overall the truck is a basic work truck, C20 307/4 speed that the few options just make better.
MODEL CE20934
4E81_ _ PICK-UP BOX FLOOR
4G60_ _ AUXILIARY SPRING EQ
4P13_ _ SIDE MOUNTED WHEEL
4Z53_ _ AMMETER-OIL GAUGE
4D29_ _ R/V MIRROR-JR-LH &
4G50_ _ H D REAR SPRING
4M20_ _ 4 SPEED TRANSMISSION
4Z52_ _ FULL FOAM SEAT
4544_ _ WHITE/RED
SS Tim is offline   Reply With Quote
Old 07-21-2013, 04:21 AM   #5
hart11b
hart11b's Avatar
Re: SPID Help
You guys are the heat! Thanks for the help. The truck was built in Janesville and I'll have a post coming soon about how/why I acquired it. Repro SPID label coming in the future.
Thread Tools
Display Modes
