Old 07-21-2013, 11:10 AM   #1
1stseries55
1stseries55's Avatar
65 GMC rear spring shackles
Has anyone been able to find rear leaf spring shackles for a GMC (2wd)?
I really just want stock replacements because the truck is low enough already (I put the axle on top of the springs).
there are some manufacturers that have some 4wd stuff and I found some F--d stuff that was close, but no direct replacement for a 65 GMC.
I bought some Western Chassis lowering ones for a 67-72 that I thought I could make work....not even close. The spring width on the 65 is 2.25"
any thoughts?
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 07-21-2013, 11:55 AM   #2
padresag
Re: 65 GMC rear spring shackles
lmc
ron
padresag is offline   Reply With Quote
Old 07-21-2013, 12:04 PM   #3
1stseries55
they don't have them....none of the standard aftermarket guys do...that is my issue
Jared
Old 07-21-2013, 01:13 PM   #4
padresag
sometimes you just have to look or think a little deeper. the 4 x 4 rears are more than likely the same as for 2 wheel drive.
ron
Old 07-21-2013, 01:37 PM   #5
1stseries55
I did not ask the question because I had nothing better to do and had not done the research 1st. The 4wd models may have the same spring width but the rear hanger is totally different and they use srew in greaseable pins..... I do not want to run that on my truck, even if it did fit I would have to change the spring bushings as well. Just need an oem style 2wd rear shackle...forget it
Jared
Old 07-21-2013, 06:11 PM   #6
Vernski
Jared try this link I think they have what you need..Vernski
http://www.autoandtrucksprings.com/c...kles-74-1.html
Vernski is offline   Reply With Quote
Old 07-21-2013, 06:41 PM   #7
gimmy 64
try early classics I know they have the lowering ones because I have them on my 64
gimmy 64 is offline   Reply With Quote
Old 07-21-2013, 07:27 PM   #8
1stseries55
Thanks guys.... appreciate the help... both of those have options that I could use..thanks again
Jared
Old 07-21-2013, 07:42 PM   #9
boucher racing
boucher racing's Avatar
I think I have a pair that are no longer in use. Let me check
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 08-06-2013, 09:21 PM   #10
1stseries55
Just wanted to post an update on this in case anyone else runs into it down the road...
I ended up using the Early Classic shackles..modified them a little so the drop is not as much.
also Moog part # SB253 is the correct part for the leaf spring bushings on these
thanks
Jared
Thread Tools
Display Modes
