Old 07-22-2013, 07:57 PM   #1
StarDust
StarDust's Avatar
need advice on conversion!
ok well i bought some drop spindles from forum member ksbrktracer and the quality on them ehhh not good ill post up some pics later on if i can but anyways the spindles are for a 1.25 inch rotor and i have a 1 rotor i do not want to spend money on reshipping and dont want to shed out 300 for beltechs at my local performance shop...from what i know i need to switch out my brakes brake calipers, and rotors but i have no absolute clue on what parts to buy!
i went to my local autozone and they told me theres no such thing a heavy duty half ton they were clueless told me theres only one size and only one size available for rotors for c10s which they say are the 1 inch rotors...i need help asap as my truck has been on jackstands for the past 2 days! plus my dad is reaaaaaaaally on my ass about this problem..
StarDust is offline   Reply With Quote
Old 07-22-2013, 08:04 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: need advice on conversion!
Buy '73 rotors and calipers.
They only come in the 1.25 hd rotor width.
Keith
Convert to disc brakes.
Old 07-22-2013, 08:12 PM   #3
LONGHAIR
Some of the confusion may come from the terminology. It's not that there is a "heavy duty" as a step-up from standard. It's just that there is a "light duty" version. The "not light" is just that standard stuff.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-22-2013, 08:49 PM   #4
StarDust
StarDust's Avatar
ok got it its going to be a pretty penny do i need new brake lines? or are they still compatable? forgot to mention that my truck is a 86 silverado...one more question and that will be it hopefully do the milling job on these drop spindled even look safe?? some poor poor milling right there quite dissapointed.
Old 07-22-2013, 09:14 PM   #5
lolife99
lolife99's Avatar
Also the HD rotor has a different inner bearing.
But I would buy new bearings also.
Since your truck is an '86 I would just get '86 HD calipers, since your brake hoses are probably now attached with a 10mm metric banjo bolt.
The 73-78 calipers have a standard 7/16-20 banjo bolt.
Keith
Old 07-22-2013, 09:51 PM   #6
StarDust
StarDust's Avatar
well i would get HD calipers for my year but the guys at autozone and oriellies look dumbfound lol and i dont seem to find HD calipers for my year please send me a link? thanks!
Old 07-22-2013, 10:01 PM   #7
lolife99
lolife99's Avatar
http://www.oreillyauto.com/site/c/de...0062&ppt=C0009
Took less than 1 minute to look up.
Keith
Old 07-22-2013, 10:02 PM   #8
lolife99
lolife99's Avatar
Detailed Description
•Overall Height: 4.95"
•Overall Diameter: 11.86"
•Bolt/Holes: 5
•Bolt Circle Diameter: 5.00"
•Nominal Thickness:
•1.29"
•Discard Thickness: 1.22"
•Type: Vented
Keith
Old 07-22-2013, 10:15 PM   #9
lolife99
lolife99's Avatar
Codes for 73-87 brake systems:
JB1 - 1" rotors with manual brakes (C-model)
JB3 - 1" rotors with vacuum-assist brakes (C-model)
JB5 - 1 1/4" rotors with vacuum-assist brakes (Any model)
JD3 - 1 1/4" rotors with hydroboost-assist brakes (Diesel engine)
JD5 - 1 1/4" rotors with hydroboost-assist brakes (Diesel engine)
Keith
Old 07-22-2013, 10:17 PM   #10
lolife99
lolife99's Avatar
1.25" Calipers from O'Reillys:
Right:
http://www.oreillyauto.com/site/c/de...3345&ppt=C0066
Left:
Keith
Old 07-22-2013, 10:54 PM   #11
StarDust
StarDust's Avatar
thanks!
Old 07-22-2013, 11:28 PM   #12
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Thank you for posting up that info Keith. We started out ordering spindles for the 1" rotors but then He remeasured and said he had the 1.25" rotor.
Now the thing that hurts is shipping stuff back and I suggested going ahead and switching over to the 1.25 rotors but I think he may have gotten ahold of one of the guys that works at my local Oreillys store. I have to look my own stuff up usually ........ !!!!! Those #s will be a big help for him.
ksbrktracer is offline   Reply With Quote
Old 07-22-2013, 11:37 PM   #13
StarDust
StarDust's Avatar
they sure will! well thanks guys ill be buying the heavy half stuff by tomorrow..
Old 07-23-2013, 12:31 PM   #14
StarDust
StarDust's Avatar
A little update..i was going to go to buy the heavy half today but then my pops stopped me and refused to let me buy the stuff because of too much work money and risk of not fitting so he basically gave me two options fork over 300+ to buy belltech spindles or call it a loss and sell the spindles i have now and try to resell them...i am in a money pit!
Old 07-23-2013, 12:58 PM   #15
lolife99
lolife99's Avatar
Why don't you just send them back and get the light duty 1" version from the same Vendor???
It was your error on rotor width.
Keith
Old 07-23-2013, 01:06 PM   #16
StarDust
StarDust's Avatar
Yes i know.it was my error thats what i was planning on to just return them and get the correct ones i had told tommy how much would it be but my pops is stubborn i guess i dont even know he wont let me upgrade to heavy half nor ship them back to tommy even though im paying everything....
Old 07-23-2013, 02:11 PM   #17
ksbrktracer
TNT-MOTORSPORTS
Edgar
Just let me know what you decide to do ...... I will work with you in anyway I can to make it as painless as possible.
No matter which way you go ........ Look in your glove box for the spid label and it should have a set of #s that may correspond with the ones Keith posted. see the list below .
Old 07-23-2013, 02:28 PM   #18
StarDust
StarDust's Avatar
Sadley i dont have a spid :/ and i just went ahead and.bought belltech drop spindles installed them right now
Old 07-23-2013, 03:23 PM   #19
ksbrktracer
TNT-MOTORSPORTS
Do you want me to figure out what it would cost to return those or do you want to try and sell them out right ... They should be very easy to sell as they fit 73-87's . Let me know
Old 07-23-2013, 05:15 PM   #20
StarDust
StarDust's Avatar
Hmm i dont know mightgive them to.a friend he wants c10 and i know this isnt your fault tommy sorry about all the comotion lol
Thread Tools
Display Modes
