Old 07-24-2013, 01:04 AM   #1
John H.
John H.'s Avatar
7040200 7042902 7041211 & 7042210 restored carbs
1. 1970 Chevy LS5 Carter. body built for Rochester dated J9 automatic carb 402 and 454. $325
This is the only carb I have left. If you need additional pictures, please let me know. It was rebuilt to factory specifications for the 1970 LS5 motor. Please look up the application 7040200.
2. 1972 7042902 dated 2601 CORRECTION: it is a 902 not a 910. Chevrolet 350 California Rochester quadrajet carb. This is a 1972 California carb for a Corvette, Camaro, Chevelle or Nova. If you look at the front, part of the bracket that the idle solenoid mounts to is damaged. $295
3. 1972 7042210 dated 1532 350 auto $295 Sold to Davestrucks
4. 1971 7041211 dated 1301 350 4spd $295
He charges me $225 plus shipping to restore these carbs so you are basically getting the rebuild, core and shipping for $295.
I had additional carbs done by a guy who has over 40 years experience rebuilding carburetors and has done thousands. This carb has just been restored and is ready to install. The rebuilding extras include NEW bronze bushings installed in base. ALL rebuilt quadrajets should have this done. The bases are aluminum and the shaft bores wear and cause poor idle and vacuum leaks. All NEW primary throttle plates are installed. They are also aluminum and wear out. The secondary air valve cams are plastic. This lifts the metering rods when the secondary’s open. They wear out or break causing a lean wide open. All NEW air valve cams are used in these rebuilds. New float installed. The main well fuel plugs are MT13 sealed. Other sealers will not hold up to today’s fuels and will leak. The accelerator pump cups are fluorelastomer and are blue in color. They are the only pump cups that will withstand today’s fuel additives. The black pump cups are no good and will swell or shrink. All NEW choke pulloffs. The secondary throttle plates are DAG213 sealed for a good quadrajet idle quality. The top and body are chemically color bond 420 dichromated.
The aluminum base is restored with a two part cleaning process that brings the aluminum back to the original finish. No silver paint or wire buffing is used. The bottom of base is then machined flat to prevent any potential warpage. The screws and linkage are yellow zinc plated. No rusty parts here. Carbs are tested on their machine that uses a pressure gauge and fuel meter. This assures no leaks and a good pump stream for the accelerator. A mounting gasket and an air cleaner gasket are included. You will not be disappointed.
Fedex Ground Shipping with INSURANCE is included.
$295 shipped to Conus for the 350 SB carbs and $325 shipped conus for the LS5 carb.
7040200
I need to resize my pictures. You may search 7042902 John H. and see pictures of the work.
John H. is offline   Reply With Quote
Old 07-24-2013, 01:15 AM   #2
John H.
John H.'s Avatar
Re: 7040200 7042902 7041211 & 7042210 restored carbs
7040200
Attachment 1135321
Old 07-24-2013, 01:20 AM   #3
John H.
John H.'s Avatar
Attachment 1135324
Attachment 1135325
7042902
Attachment 1135326
Attachment 1135327
Attachment 1135328
7041211
Attachment 1135329
Attachment 1135330
Attachment 1135331
7042210
Name:  210 number.JPG
Name:  210 drv side.JPG
Name:  210 pass side.JPG
Old 07-24-2013, 01:23 AM   #4
John H.
John H.'s Avatar
Attachment 1135335
Attachment 1135336
Name:  902 number.JPG
Name:  902 drivers .JPG
Old 07-24-2013, 01:24 AM   #5
John H.
John H.'s Avatar
7041211
Name:  211 number.JPG
Name:  211 pass side.JPG
Name:  211 drv side.JPG
Old 07-24-2013, 01:36 AM   #6
70LonghornCST
Moderator
70LonghornCST's Avatar
If you come across a carb for a 1970 350 with an automatic for a California application, I will buy it. These are beautiful carbs!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 07-24-2013, 01:43 AM   #7
bronze 72 super
bronze 72 super's Avatar
John, I'm interested in that carb for the 70 402. If I can swing it and you still have it by the end of August when I come up would like to buy it. I plan on coming up Friday the 30 of August, that's the only time I can make it. I plan on being there early in the morning. I'm still interested in those other parts I talked about earlier. Please let me know your thoughts on this. Thanks Mike.
bronze 72 super is offline   Reply With Quote
Old 07-24-2013, 05:36 AM   #8
gmc 2500 4x4
wow! nice!
gmc 2500 4x4 is offline   Reply With Quote
Old 07-24-2013, 08:25 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Real nice work. I would take a 72 California emissions carb but can you confirm the number on that described in #2 above? There are 6 rather than 7 digits given. I thought the third digit was a "4" for 70-75 application with the fifth digit a "5" to denote CA emissions. Thanks, Pete
Old 07-24-2013, 09:30 AM   #10
John H.
John H.'s Avatar
Hey Pete, it is 7042902. Typo. You can see it on one of the pictures. Also, I am building your k20 twin. Factory orange super K20 4x4, ac, tilt, parchment, slider, door edge guards. Adding tow hooks, tool box, tach speedwarning and possible shoulder harness if Wes does not hold them hostage!
Bronze 72: Mike, we will work something out when you are up here on the 70 carb.
Correction: Pete i had it in my mind it was a 910 ending CA carb. It is for CA: 1972 Corvette, Camaro, Chevelle, or Nova or specific for truck!
Old 07-24-2013, 11:52 AM   #11
yote1234
yote1234's Avatar
looking for one for my 72 super auto with 402 v8.. got one?
think it should be 7042210? or 7042510?
if 7042210 is correct i will take it...
dave
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 07-24-2013, 01:27 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by John H. View Post
Hey Pete, it is 7042902. Typo. You can see it on one of the pictures. Also, I am building your k20 twin. Factory orange super K20 4x4, ac, tilt, parchment, slider, door edge guards. Adding tow hooks, tool box, tach speedwarning and possible shoulder harness if Wes does not hold them hostage! Correction: Pete i had it in my mind it was a 910 ending CA carb. It is for CA: 1972 Corvette, Camaro, Chevelle, or Nova or specific for truck!
Nice John! I didn't happen to see a build thread but if/when you get one going please let me know. I've made a lot of mistakes along the way and would be glad to share any details that would help with your build. Those shoulder belts may be the ones Wes pulled from a Blazer - tempting for sure!
Good to know about the "9" referencing CA Q-jets as the few decoding sources I know of make mention only of a "5" for CA emissions carbs. I'm keeping an eye out for a CA carb for my 72 Blazer - which has all the CA emissions equipment in place but the carb code isn't correct (it's more of a want rather than a need right now). What concerns me with this carb is the mounting tab for the idle stop solenoid - my Blazer has A/C and I wouldn't want a loosely mounted idle stop solenoid.
Thanks! Pete
Old 07-24-2013, 09:03 PM   #13
davestrucks
I'll take it. 7042210 (72 350 auto)
davestrucks is offline   Reply With Quote
Old 07-24-2013, 09:31 PM   #14
RPIcka
If you got a Q-jet for a 1972 K-10 with a 350 I'd be interested.
'72 K10
'94 K2500
RPIcka is offline   Reply With Quote
Old 07-24-2013, 09:49 PM   #15
davestrucks
yote1234 what you need is a 7042218 4bbl 72 402 10 auto
Old 07-24-2013, 10:01 PM   #16
davestrucks
RPIcka if yours is auto get in line 7042210 if manual 7042211
Old 07-24-2013, 10:11 PM   #17
John H.
John H.'s Avatar
7042210 sold to Deavestrucks pending payment.
Old 07-24-2013, 10:21 PM   #18
RPIcka
If you got another one for an auto let me know
'72 K10
'94 K2500
Old 07-24-2013, 10:49 PM   #19
John H.
John H.'s Avatar
The 902 is a 72 automatic carb with one additional port that can be capped. The 211 will work for an automatic if numbers are not an issue.
These are pretty good values.
Old 07-25-2013, 12:09 AM   #20
RPIcka
What I'm looking for is a q-jet with electric choke that I can bolt on. Something that has been rebuilt like what you have listed sounds great.
'72 K10
'94 K2500
Old 07-25-2013, 08:22 AM   #21
John H.
John H.'s Avatar
7042210 is sold to Davestrucks.
7042902 and 7042211 are still available.
Old 07-25-2013, 10:44 AM   #22
yote1234
yote1234's Avatar
thanx davestrucks. very much.
Hey John.H put me in line for the next "7042218 IU" when and if you get one. thx,dave
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 07-25-2013, 10:00 PM   #23
Critterman71
Critterman71's Avatar
man I need a carb for a 71 c-20 402 with air conditioning and an auto if you have one restored or not let me know thanks
Critterman71 is offline   Reply With Quote
Old 07-26-2013, 01:30 AM   #24
John H.
John H.'s Avatar
I only have the 7042902 and the 7041211. I just have the core for my project.
Old 07-27-2013, 12:08 PM   #25
John H.
John H.'s Avatar
Weekend bump
Thread Tools
Display Modes
