07-24-2013, 01:09 AM | #1 |
Task Force - Gas Pedal Binding
Yeah, I DID a search on "gas pedal". I came up with THIS:
http://67-72chevytrucks.com/vboard/s...archid=3838120 All the 47-59 "gas pedal" threads. Nothing mentions problems with binding. I took mine off, wire wheeled everything, painted, lubed with white molybdenum grease and it still binds slightly and will not return fully to idle. I am missing a pedal so I just hook my toe under the rod to get it to return to idle but obviously, that is not gonna cut it. Yes, I can and MAY go with an eBay aftermarket gas pedal/cable assembly but it seems like it shouldn't be a hard thing to fix. Am I missing something simple? Yes, the return spring is nice and strong and the carb doesn't seem to be binding.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-24-2013, 11:20 AM | #2 |
Re: Task Force - Gas Pedal Binding
Nothing, huh?
I'm the ONLY guy who has had this binding issue? I think I'm going to take it all apart again and friggin "microscopically" examine each part for a burr, wear, something that could be the problem. Part of the reason for doing this is I'd like to be able to just buy a $13 replacement rubber gas pedal... http://www.truckandcarshop.com/trucks47_59/t47_022.html ...than to have to drop $50-60 for an eBay Chinese Lokar knockoff, or a $150-160 real Lokar pedal assembly (which MAY be made in China anyway!)
07-24-2013, 11:26 AM | #3 |
i found mine was doing the same thing when I was trying to get the throttle linkage set up. I found it was in the sleeve that passes through the firewall. I gave it a shot of WD 40 and worked it until there wasn't any more binding
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
07-24-2013, 11:42 AM | #4 |
07-24-2013, 12:04 PM | #5 |
Ha ha, it'll be funny if; after all the fretting I've done over it, a little WD fixes it!
But ok, I'll try it before going home today and taking it all apart again.
07-24-2013, 02:29 PM | #6 |
post a picture of your linkage, that would help to determine if it's stock and maybe diagnose a fix
stock linkage is pretty basic, not many pivots or bind spots most problems are caused by the back of the stock pedal wearing out
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-24-2013, 04:18 PM | #7 |
Yeah, you're right about posting a picture....but I'm posting from my desk at work, sheesh!
The assembly at the toe/firewall is all stock. It's the part I took off to wire wheel, paint, lube. I replaced it on the firewall with new bolts - just cause the old ones were mismatched, but that should make no difference. There is no pedal. I have simply been steeping on the end of the rod and pulling it up with the toe of my shoe to get the truck back to a full idle. I'll take a photo later today and post tonight.
Thread Tools | |
Display Modes | |
