07-02-2003, 11:25 AM | #1 |
Eng miss high rpms
My engine seems to miss when I punch it or when it kicks into passing gear If I stay in it it goes away what could this be?
07-02-2003, 11:49 AM | #2 |
What kind of carb, motor?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
07-02-2003, 12:06 PM | #3 |
327 4 barrel quad
07-02-2003, 04:04 PM | #4 |
could be a problem with your distributor, if you still have points system check the points condition or setting or could also be the condensor and or coil or cap or rotor condition,when was the last time you tuned it up last time you changed plugs,plug wires ???these things do need routine maintenance better to change things on a schedule than to wait for them to fail
07-02-2003, 07:32 PM | #5 |
Back air valves opening too soon. Do you know how to adjust ?
07-02-2003, 07:58 PM | #6 |
Wiseass secured himself a BAN
I'm with cdowns on this one.
07-02-2003, 08:58 PM | #7 |
My Model A had a slight miss around 160 mph, but getting rid of the Mallory Unilite and switching to a marine HEI fixed it.
07-02-2003, 09:15 PM | #8 |
My dirt track car has the same problem but it sounds like a stutter box at the end of the straight away when it's turning about 6700 RPM. I don't know whats wrong with it any ideas?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
07-02-2003, 10:03 PM | #9 |
Common occurrence when timing is off.
Thread Tools | |
Display Modes | |
