Old 07-25-2013, 03:42 PM   #1
Zonecone
Vin location
Anyone know we're vin number locations are on 75 1/2 ton 4x4 short bed Chevy and 84 3/4 crew can long bed 2wd are located. Frame locations.
Last edited by Zonecone; 07-25-2013 at 03:43 PM. Reason: Auto correct on iPhone sucks
Zonecone is offline   Reply With Quote
Old 07-25-2013, 03:59 PM   #2
KrazyRay
KrazyRay's Avatar
Re: Vin location
They are on top of the passenger frame rail under the cab. Really tough to see if the cab is mounted.
KrazyRay is offline   Reply With Quote
Old 07-25-2013, 04:00 PM   #3
Zonecone
Re: Vin location
Both of them. Is there any other secret spots.
Old 07-27-2013, 07:00 PM   #4
Axle
Axle's Avatar
Re: Vin location
On my '83, the last half of the vin is stamped on the flange around the hole in the firewall for the blower motor/heater core. You'll need to remove the cover to see it.
Axle is offline   Reply With Quote
Old 07-28-2013, 08:52 PM   #5
esbstuff
Re: Vin location
and under the bed, on the pass frame rail, just behind the cab.
The 73-74's also had it on the driver frame rail, by the steering box... Maybe 75?
esbstuff is offline   Reply With Quote
Old 07-28-2013, 08:54 PM   #6
esbstuff
Re: Vin location
I have never seen one there... Can explain farther? Pic?
Old 07-28-2013, 09:21 PM   #7
Zonecone
Re: Vin location
Cool thanks guys. Any more locations by any chance. I'm doing cab swap and just don't want to be hassled by the man if I get pulled over.
Old 07-29-2013, 07:05 AM   #8
Keith Seymore
Keith Seymore's Avatar
Re: Vin location
I also was not aware of a hidden VIN on the cab anywhere. We did stamp a three digit cab shop build sequence number on the upper radius of the cowl panel but I was not aware of anything in the heater box area.
Axle - do you know which plant that truck was built in?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-29-2013, 10:10 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Vin location
thought i'd seen numbers there too,when the box was out,I wana say my 88
never checked them tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-29-2013, 10:33 AM   #10
Big bad Green
Big bad Green's Avatar
Re: Vin location
What does the frame vins tell you ?
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
Old 07-29-2013, 10:39 AM   #11
Keith Seymore
Re: Vin location
It tells you if your cab or frame has been swapped.
If the cab, frame and title match - you're good.
If they are different - then there's some history there that you'll want to uncover.
K
1979-1986
1986 - 2019
Old 07-30-2013, 06:22 PM   #12
Axle
Axle's Avatar
Re: Vin location
Oshawa, Ontario Canada.
Alex.
Not my photo attached, just the orange box and arrow. =-)
(okay, why do we have such a ridiculously small image size limitation for attachments? 642 pixels wide? Come on...)
Old 07-30-2013, 09:02 PM   #13
Keith Seymore
Re: Vin location
Alex.
Interesting. I wonder if that is an "Oshawa only" thing.
K
1979-1986
1986 - 2019
Thread Tools
Display Modes
