Old 07-02-2003, 01:25 PM   #1
FrankHoy
FrankHoy's Avatar
rear emergency cable
Does anyone have a source for these cables for a 72 GMC 1/2 ton 4X4? I have found them at local parts stores but they are not they same as originals(shorter and not as heavy duty). I fear they will not last or may break if axle is over extended. I also have found that it apparently makes a difference what trans you have. I assume this is to accomadate longer tailshaft clearance. Which makes me wonder what would be the application to use for a converted 700r4, as opposed to the 350 or 400 trans.
Any help greatly appreciated.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 07-02-2003, 03:34 PM   #2
ljbear
ljbear's Avatar
Frank,
I purchased mine through In Line Tube . The offer OE replacement as well as stainless steel. I had them make mine about 3" longer to accomodate my lift. With that said, I have a used set from a 71 SWB 4x4. Cables are good, with wear marks on the rubber protector from rubbing on the leaf springs for 30 years. Just need to be lubed and cleaned.
LJ
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Thread Tools
Display Modes
