Old 07-02-2003, 04:36 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
temp gauge troubles?
my temp gauge started reading way way way to the right for no reason. i figured it was the temp sending unit.. so i just replaced it. same thing....
the wire is live. has 12 volts at the clip. when i ground it out, the needle does move back to the left a bit, but i have to ground it a few times.
so im guessing that the gauge is gone.... anyone have the same prob?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 07-02-2003, 05:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting...the guage should tach out to hot when you ground out the green wire.
Old 07-02-2003, 05:29 PM   #3
mtdave2
mtdave2's Avatar
hum, maybe the wire is grounding someplace... let me go put an ohm meter on it..... key off =)
69 k10 Suburban
Old 07-04-2003, 11:39 AM   #4
mtdave2
mtdave2's Avatar
anyone have this happen??? i hate to replace the gauge for nothing...
69 k10 Suburban
Old 07-04-2003, 11:49 AM   #5
Southpa
Southpa's Avatar
Yeah been there Dave. I figure either the gauge or some grounding problem. Could never get it fixed so I installed a mechanical gauge/sensor system. If you go that route and it still reads off the map then you got some engine problems, .
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Thread Tools
Display Modes
