07-30-2013, 09:44 AM | #1 |
Project Heaven in my 67!!!
What is that....
On the back of the speedometer on an 87 there is a set of wires that go into a small green box that has a circuit board in it. I replaced the dash with a 91 Tach Dash and it doesnt have it. What is that doohickie and do I need it???
07-30-2013, 10:21 AM | #2 |
BAD BOW-Silverado XST
Re: What is that....
It's an optical sensor for cruise control.
07-30-2013, 10:52 AM | #3 |
Slots go on anything!
It also supplies the VSS signal. You need that with TBI.
1974 Jimmy- 5.3/4L80e/NP241 |
07-30-2013, 12:32 PM | #4 |
So how do I use this setup in my 87 so I can have the tach? Remove all the gauges from my 87 dash and put all the gauges minus the speedo from the new dash back in and use the printed circuit from the new dash?
07-30-2013, 02:36 PM | #5 |
The tach dash is out of a 91? What does the back look like?
07-30-2013, 04:38 PM | #6 |
07-30-2013, 04:41 PM | #7 |
This is a pic of the actual dash... |
07-30-2013, 06:48 PM | #8 |
I think the easiest way to go would be to transfer your 87 speedometer (with it's VSS) over into that tach cluster. I believe it will involve some minor modifications to the plastic housing to make it fit. But trying to fit the tach and small fuel gauge into your non-tach cluster housing would require even more modifications.
07-30-2013, 09:00 PM | #9 |
Yes the tach dash you have is earlier, pre-electronic cruise era.
Speedometer should be an easy swap out to your current speedo. You may have to enlarge the opening for the VSS head. Since you have an 87, you need to retain the VSS for proper operation of the TBI system. Plus your mileage stays accurate. |
Thread Tools | |
Display Modes | |
