Old 07-30-2013, 10:10 PM   #1
Drewski23
question about bleeding the front brakes? (drum)
novice question here..ive got a 69 and ive got the entire brake assembly off because im going to discs. On the passenger side the fluid is all drained out...you can see the hole in the bottom of the master cylinder. The other side of the car I took the brakes off the same way and im not getting any fluid to come out..doesnt matter if i press the brakes or not. One section of the master cylinder is still full...what gives?
Drewski23 is offline   Reply With Quote
Old 07-31-2013, 04:35 PM   #2
slepysal
slepysal's Avatar
Re: question about bleeding the front brakes? (drum)
Not sure what you mean. The master cylinder is devided into two circuits Front/Rear and not left /right
You shouldn't have to bleed the system untill you have all the new brake components hooked up.
Also keep in mind that you will need to swap out your master cylinder from your drum/drum to a disc/drum unit.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-31-2013, 04:54 PM   #3
Drewski23
Man im a dumbass lol. I just took the brakes off because im re doing the suspension and ill be re doing the brakes also so i wanted them out of the way. Thanks for the help
Old 07-31-2013, 05:49 PM   #4
cdowns
cdowns's Avatar
you will need to add a proportioning valve to your new disc/drum master cyl as that 69 only has a distribution block
Old 07-31-2013, 06:04 PM   #5
slepysal
slepysal's Avatar
x2
Old 07-31-2013, 09:43 PM   #6
Drewski23
ah, thanks again..here i was thinking that was the proportioning valve.
Thread Tools
Display Modes
