Old 08-02-2013, 08:37 PM   #1
86c20
86c20's Avatar
my streeing is off
ok so i took my 85 k30 to ri to see my wife and on the 70 mile drive the streeing wheel turned 90* to go straight. got to her place looked at it. tie rods where gone ok so get home change those out and it is still turning on me. also when i turn the wheel the lelfs on the drivers side move alot and it looks like the frame is moving to. WTH? i am lost
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 08-02-2013, 08:57 PM   #2
Oldriginal86
Re: my streeing is off
Might want to check the frame around the steering box for cracks. Sounds like it should be parked until you figure it out.Try getting someone to turn the wheel while checking all suspension components.
Oldriginal86 is offline   Reply With Quote
Old 08-02-2013, 10:03 PM   #3
Billy81
Billy81's Avatar
Yeah that does sound like it broke the frame right around the steering box my Uncle had a blazer do this same thing but he kept driving it that way and eventually the frame just split.
Billy81 is offline   Reply With Quote
Old 08-02-2013, 10:48 PM   #4
86c20
86c20's Avatar
!@#$ that is such crap lol. i will look tomorow is there any way to fix or is it now junk?
Old 08-03-2013, 09:04 AM   #5
Kingjasn
Kingjasn's Avatar
Nahh, it's fixable. If there is a crack in the webbing of the frame, just get a competent welder to grind it out and weld it. If it is done right, it won't compromise the integrity of the frame. You could also cut a 1/4" piece of plate and bolt it to the inside of the frame. Just make sure to use 1/2" or 5/8" grade 8 bolts, with about a 1/2" shoulder.
Kingjasn is offline   Reply With Quote
Old 08-03-2013, 01:32 PM   #6
86c20
86c20's Avatar
ok so i looked closer at the frame i see no cracks but the box is leaking alot. and the big thing is i need this truck up and rumming soon. could it be the box is no good and it is drifting???
Old 08-03-2013, 05:13 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If your steering wheel went 90 degrees off, you have a real problem. You just haven't found it yet. Something is broken. Not worn, broken. If the box has somehow failed internally to cause this, you have steel and iron parts that are damaged. Leaks don't mean anything to this deal.
Old 08-04-2013, 12:46 AM   #8
nheller76
nheller76's Avatar
Have u changed the fluid in the power steering pump? That will tell u If the internals are shot on the box, u will need to unhook it and dump the fluid out. See if there are any metal shards. I was having issues with mine too and buy doing this I found out my box shredded some stuff.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-04-2013, 01:59 AM   #9
86c20
86c20's Avatar
i have not checked the box at all. was thing how to check it tho. i dont see where it could be anything else but idk. she dont have big tires (33) and i dont do off road but i do work her
Old 08-04-2013, 02:11 AM   #10
franken
Get under it and eyeball things. As mentioned, you'll probably notice something out of place.
Any funny feeling when driving and turning the wheel?
I bought a Camaro a while back and when turning found it liked to steer itself more into the turn on say cloverleaf exchanges. A rebuilt box took care of that problem.
Note that some suggest new hoses and a rebuilt pump when replacing the box. Apparently due to metal shavings in the fluid.
I've heard the same suggestion for auto transmissions. My Jeep had metalflakes in the fluid after my friend roasted the TH400 as payback years ago. So it may be a good idea to view it as a system.
I'd guess $200 for all parts. Ask for a 72 box. The later boxes had a better ratio if I remember correctly.
If the PS pumps don't match, you can buy a bare pump. The pumps are almost all the same. The cans (tanks) vary.
franken is offline   Reply With Quote
Old 08-04-2013, 05:12 AM   #11
chengny
chengny's Avatar
Check your connecting link assembly especially the adjusting clamps. Shortening/lengthening that link by only one turn of either clamp will move your steering wheel more than 90 degrees of center. It is really touchy.
BTW - that is how to re-align your steering wheel when you find the problem. It moves both wheels at once - no fooling around with tie-rod ends.
chengny is offline   Reply With Quote
Old 08-04-2013, 08:39 AM   #12
86c20
86c20's Avatar
i am so ude to 2wd trucks i forgot about that adjuster. i will go look at it and see maybe it is lose. heres to hoping lol if not i will check the fluid also.
thanks guys
Old 08-04-2013, 01:00 PM   #13
wraprail
wraprail's Avatar
Ummm....lose nut behind the wheel maybe?? lol
I am kidding of course.. Keep us updated. I am at a loss myself...
wraprail is offline   Reply With Quote
Old 08-04-2013, 01:43 PM   #14
86c20
86c20's Avatar
ok so it was a few lose nuts but not behind the wheel. who ever replaced the rear tie rods that have the adjuster for the wheel thought it best not to even think of tighting them. so it is alot better now. but i find that the steering still sucks balls in this truck as she dont turn at all
Thread Tools
Display Modes
