Old 08-09-2013, 04:50 AM   #1
lasher78
lasher78's Avatar
trans hump size?
can someone tell me if this is the high hump or low hump tunnel or if photo not good enough tell me how to tell diff. truck was orginally a column shift bit PO changed to 350th floor shift. need to figure out for rubber floor mat im looking at buying from stock interiors.
live like you are dying
lasher78 is offline   Reply With Quote
Old 08-09-2013, 05:43 AM   #2
donthekawguy
donthekawguy's Avatar
Re: trans hump size?
That is a low hump. I have a high I just found out.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-09-2013, 09:03 AM   #3
racecougar
racecougar's Avatar
Agreed. That's definitely a low hump.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 08-09-2013, 10:13 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
For comparison, this is what a high hump looks like:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-09-2013, 01:17 PM   #5
lasher78
lasher78's Avatar
thanks everyone....
thanks markeb01 for the photo to compare to..
Old 08-09-2013, 01:21 PM   #6
lasher78
lasher78's Avatar
as you can see in my photo my floors are a little rusty (surface) and dirty as heck. what would be the best way to clean them up so i can put primer or bedliner material on it. i dont have a dande blaster so that is out...
Old 08-09-2013, 01:48 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
big 90* wire wheel and good protective equipment (it WILL chuck little wires at high speed at your face.) It'll take everything off without damaging the metal, be careful around areas with dried seam sealer etc, they create a good amount of debris with the wheel hits them. If the rust is into the metal at all, hit it with some POR 15 before you put a bedliner on it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Thread Tools
Display Modes
