Sometimes Stripping is a bad thing...
Well I was putting in a new turn signal switch and when I went to put the steering wheel back on, I stripped the shaft while trying to bolt it back on. I looked on here and saw there were a couple others with the same issue and had some trouble trying to re thread it and or buying a new nut for it. So can I just replace the shaft itself? if so how do I take it out? Thanks, and I'll post a pic of it.
Re: Sometimes Stripping is a bad thing...
As cheap as I may sound, I want to replace as little as possible, I'm a poor college student lol. Can I just replace the stripped shaft? and how?
Old Duffer
![]() Join Date: Mar 2003
When the steering wheel is on and seated, how much good thread is sticking out?
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
I had that happen before. I took a file to it to get it a tiny bit smaller, then re-threaded and put on a nut and washer.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
There is barely any good threads sticking out when the wheel is on.
There are less good then there is bad sticking out. That file idea is a good one. |
Old Duffer
Lattimer's fix sounds good to me.
You just need to get it small enough for the next size down die to fit it. Then carefully thread it, install new nut and washer.
Active Member
![]() Join Date: Jul 2007
Yeah, rethreading would be the cheapest and easiest thing to do. If you go this route be sure and wrap a cloth around the column to protect it from metal filings. I would even cover the floor board with newspaper.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Thread Tools | |
Display Modes | |
