08-17-2013, 05:09 PM | #1 |
Add-on pulley for AC???
This is my last change to tried to investagate if adding AC to chevy 250(easy/cheap). I saw at thepartguy.com sells this add-on pulley. This is realiable or has somebody tried this???
My chevy 250 engine is running with 2 grooves pulley but before I a sanden compressor/AC system, I need to know if this possible. An easy solution without adding pulley to Alt, steering pump or installing 3 grooves pulley. Please look at the pics one is for crankshaft and other is water pulley. |
08-17-2013, 05:11 PM | #2 |
Re: Add-on pulley for AC???
08-17-2013, 05:12 PM | #3 |
Is it worth all the trouble having Inline6 with AC???
08-17-2013, 05:14 PM | #4 |
this looks like add-on??? but will the outer groove line up with the AC???
08-17-2013, 05:54 PM | #5 | |
I would get ahold of the seller and ask some questions. They might be able to help. I can't see the pulley being a problem. The biggest issue with an aftermarket A/C is the fwd-aft placement of the compressor, which will determine if the belt will align with the A/C pulley on the crank.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
08-18-2013, 12:35 AM | #6 |
60-66 Nut
That pulley looks to be the same pulley used on the small block with a short water pump, for driving the power steering pump. I don't remember for sure, but it seems like that does bolt up to the 230/250 balancer/pulley assembly.
08-18-2013, 07:55 PM | #7 |
I have a factory ac compresser bracket for a 6 came off a 292 i will need to check i think i might have the pulleys? If somebody is looking?
Thread Tools | |
Display Modes | |
