08-19-2013, 12:21 AM | #1 |
driveshaft interchange
I have an 80 short bed with an I6 and 3 on the tree. Wanted to know if I can still use the same driveshaft behind a TH350 with a long tail shaft? Wanting to swap a 350/350 combo I have ready to go.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
08-20-2013, 02:24 PM | #2 |
Re: driveshaft interchange
bump
08-20-2013, 03:04 PM | #3 |
Do you own a tape measure?
Easy to measure from the front of the bellhousing to the tailshaft of the tranny on both of them. |
08-20-2013, 03:30 PM | #4 |
If you have both setups you can measure as the ^^ mentioned.
Something else to check is if the slip yoke on the drive shaft uses the same splines on both tailshafts. I've had driveshafts resized for about $150-$175 including balancing locally, that is an easy enough fix. If they need to swap a new slip yoke that is easy for them to do at the same time too, probably another $70. |
08-20-2013, 04:09 PM | #5 | |
08-20-2013, 04:11 PM | #6 | |
08-20-2013, 04:36 PM | #7 |
I assumed you where putting the 350 back in at the same bell location. You didn't say. If you measure them both and figure out the difference (if there's is a difference) then you can move your motor so you don't need to mod your ds.
Thread Tools | |
Display Modes | |
