Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-22-2013, 04:43 PM   #1
JointTech
JointTech's Avatar
I've got gas
hehe, sometimes I crack myself up...
I got a tank with co2/argon today.
My welder came with a regulator.
So what now? I just plug the tank into the welder and turn on the gas? The welder does the rest as far as amount of gas released etc?
I lost my owners manual and it would probably all be in chinglish anyway.
I also got some non-flux core .023 wire.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 08-22-2013, 06:50 PM   #2
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Re: I've got gas
What welder do you have?
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 08-22-2013, 06:53 PM   #3
vidman
vidman's Avatar
Re: I've got gas
hook up your regulator to your tank, the hose to back of welder and your good to go. You will have to set the pressure of the regulator to suite your welding needs. some run 20lbs some use 30lbs I,ve seen guys run as much as they can. sometimes it depends on which gun you have and how clean your steel is that your using. don,t waste your gas if your welding outside because the wind will blow it all away from your work. use flux core if welding outside..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-22-2013, 06:55 PM   #4
JointTech
JointTech's Avatar
Re: I've got gas
this is the welder i have
http://www.northerntool.com/shop/too...FRDZQgodHwkAsA
wait actually its this one. http://www.realgearusa.com/ i got it from gts-weldco. looks to be the same as the NT one though. probably made in the same Foxconn factory. :P
72 C20 Long Bed
Old 08-22-2013, 09:54 PM   #5
sams60gmc
sams60gmc's Avatar
Re: I've got gas
also switch your leads if going from flux to gas.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 08-22-2013, 11:00 PM   #6
cableguy0
Re: I've got gas
15-20 on the regulator and you will be in good shape. I have the same welder. I have welded everything from sheetmetal to spring perches on a rear with that welder and all is well.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-22-2013, 11:02 PM   #7
JointTech
JointTech's Avatar
Re: I've got gas
i think i bought it on your recommendation
im going to give it a shot tonight. thanks guys!
72 C20 Long Bed
Old 09-29-2013, 09:29 PM   #8
sams60gmc
sams60gmc's Avatar
Re: I've got gas
.023 solid core would be the best in those little machines
Old 10-29-2013, 08:54 PM   #9
Tinkermc
Re: I've got gas
I had gas but 10 Rolaids and 10 minutes and all was well, ha! Ha!
Tinkermc is offline   Reply With Quote
Old 11-06-2013, 04:32 AM   #10
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: I've got gas
haha! JointTech you were asking for that one!
ETsC10 is offline   Reply With Quote
Old 11-16-2013, 03:28 PM   #11
killerpanel
Re: I've got gas
Nice little welder. It's the same as a Hobart All made by Miller.
killerpanel is offline   Reply With Quote
Thread Tools
Display Modes
