08-23-2013, 03:06 PM | #1 |
ECE 2.5 drop spindle
I am going to run ECE 2.5 drop spindles up front on my 72 2 wheel drive. Anybody see any problem with running 15x10 wheels up front. 3.5 inch back spacing. Any pictures.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
08-23-2013, 05:01 PM | #2 |
Re: ECE 2.5 drop spindle
I have no experience with what you are asking, but people are running into issues with rubbing the lower control arm with a 15x8 wheel and that drop spindle, I would think that a 10" wheel would make it worse. I'm also not sure on the backspacing, typically I take the wheel add an inch for the bead and divide by 2.
Anthony '67 Shortstep (555/T56) '67 Parts Truck (TBA) |
08-23-2013, 05:30 PM | #3 |
Watch out for your cornhole !
With only 3.5 backspacing you shouldn't have any issues. If you couple it with a drop spring though, the lowness is going to close up the fender gap enough that you're gonna risk rubbing the outer fender lip. Just a spindle though, and reasonably short tires, you should be fine.
08-23-2013, 08:05 PM | #4 | |
08-23-2013, 08:08 PM | #5 |
Worst case, you trim the lower arm a tad. It only takes a minute or two with an angle grinder. Absolutely nothing to be concerned about.
Posted via Mobile Device |
08-23-2013, 10:10 PM | #6 | |
Thread Tools | |
Display Modes | |
