Old 08-25-2013, 05:26 PM   #1
j-dogg
Alan Grove low mount a/c bracket for ls motor
Has anyone used the Alan Grove low mount ls truck motor low mount ac compressor bracket? I'll be doing the ls swap soon and am trying to keep the ac compressor in the low position without trimming the frame or fabbing my own motor mounts. I can't tell from the pictures on their website, but it looks like there might be enough clearance with this setup to use most aftermarket motor mounts without needing to modify them.
http://www.alangrovecomponents.com/LS.htm
j-dogg is offline   Reply With Quote
Old 08-26-2013, 10:34 PM   #2
j-dogg
Re: Alan Grove low mount a/c bracket for ls motor
Bump. Anyone have an opinion on if it looks like it'd work??
Old 08-26-2013, 10:52 PM   #3
69sinker
69sinker's Avatar
Ill take a look at my truck tomorrow night, but I don't think it will work without trimming frame. Stay tuned.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 08-27-2013, 07:50 AM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Just a FYI, I get a Malicious URL warning everytime I open this particular thread. I wouldnt click on anything.
--Josh
Old 08-27-2013, 08:26 AM   #5
67 chevelle
67 chevelle's Avatar
sanden 7176 compresor
gm 38194 tensioner
a couple spacers and simple brackets you fab , the spacers I made from 3/8s ridged
I have camaro power stearing , and alternator on the drivers side of engine but the truck drive works just as well , truck water pump
67 chevelle is offline   Reply With Quote
Old 08-27-2013, 09:18 AM   #6
67 chevelle
not ridged , galvanized
Thread Tools
Display Modes
