Old 08-25-2013, 10:38 PM   #1
nolimitssjca
C20 Front brake drum removal
Tried removing the front brake drum but this drum has 2 flat head screws in it.
I tried:
  • Heat
  • Lubricant
  • Impact screwdriver
  • Chisel (break loose the rust)
They won't budge. Any ideas? Can I drill them out? If so can I find replacements?
nolimitssjca is offline   Reply With Quote
Old 08-25-2013, 11:07 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: C20 Front brake drum removal
Try drilling them out. Probably don't need to replace them since lug nuts hold them on. Maybe remove the front wheel bearing and see if you can pull the whole thing off.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-26-2013, 12:49 AM   #3
Mister-B
Yeah, pull the cap cover off, straighten and remove the pin, then pull off the bearing and the whole thing should slide off. It happened on mine when TBone and I replaced my front brakes.
Mister-B is offline   Reply With Quote
Old 08-26-2013, 07:13 AM   #4
cdowns
cdowns's Avatar
original drums are rivited in place from the factory on the hubs and need to b drilled out in order to remove the drum from the hubs
Old 08-26-2013, 08:15 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Are you replacing the drums?
If yes, then you need to find a way to remove the screws. It sounds like it is time for the drill.
If you are not replacing the drums then as Mister-B mentioned, pull the drum and hub together.
TBONE1964 is offline   Reply With Quote
Old 08-26-2013, 08:16 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
True but not on a C/20
Old 08-26-2013, 10:04 AM   #7
Orange67
Orange67's Avatar
Whoa guys! no drilling required on a C20. What you need is what they call an "impact driver", to remove those flathead screws. Sears will be your best bet. They are still a bugger to get out, but take your time, make sure you don't strip them out, or you WILL have to drill them out. Basically what an impact driver does, you push the screw tip in and twist the direction you need to turn the screw, and hit it with a hammer. All four corners of a C20 will have these flathead screws.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 08-26-2013, 10:15 AM   #8
sboris
sboris's Avatar
I think he tried the impact.. ^^
Just pull the whole hub as mentioned. I did mine with relative ease, but that was several years ago, 16 years newer.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 08-26-2013, 10:48 AM   #9
Orange67
Orange67's Avatar
LOL sorry nolimit, somehow I missed the "impact screwdriver" in your list..... yikes, I guess either pull the assembly off or drill the heads off as mentioned. guess I better stick to "baffling them with bull".....
Justin
Old 08-26-2013, 10:58 AM   #10
sboris
sboris's Avatar
Lol. Hey I read over stuff all the time. Maybe my eyes need checked? Nah..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 08-26-2013, 11:02 AM   #11
nolimitssjca
I was hoping to put new shoes on and call it a day. If I pull the hub isn't the drum still attached?
Old 08-26-2013, 11:25 AM   #12
heyjoe
I say the following as a long time C20 owner.
If you are just replacing shoes then there is no need to separate drum from hub. Pull the hub and drum as one unit. You will be able to clean and inspect the wheel bearings & races. Then repack with grease, install and adjust.
heyjoe is offline   Reply With Quote
Old 08-26-2013, 11:30 AM   #13
68gmsee
Active Member
68gmsee's Avatar
^ Yes.
If drums need turning take the whole asm in to a machine shop. Usually they can drill the screws out for a little extra.
06 Trailblazer
Old 08-26-2013, 11:41 AM   #14
nolimitssjca
Now we're making progress!
Old 08-26-2013, 11:46 AM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
Progress and Education
If the drums need to be machined it is best to leave them mounted to the hub. The shop can mount a drum/hub assembly the same way they mount a rotor with a built in hub. This will insure the least amount of run out for the assembly.
Old 08-26-2013, 03:45 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've even seen guys pull the hub/drum/tire/wheel all in one piece to change shoes on one that wasn't too worn.I don't recall if it was a 67-72 but I believe the adjuster holes were in the backing plates and accessible with the tire/wheel on.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-15-2014, 04:09 PM   #17
nolimitssjca
I know this thread is old but I figured I should finish it off.
Back in the 70's I helped my dad change the brake shoes on his C10. As most of you know the wheel comes off and the drum comes off (straight forward).
What is different about the C20 is the wheel comes off, then you remove the dust cover, wheel bearing nut, and that releases the bearing and drum together.
I remember dad struggling with pliers and screw drivers to put springs back on. Having the right brake tools makes the job MUCH easier.
I still need to do the rear brakes but knowing the C20 process is different is worth noting.
brake drum removal
Thread Tools
Display Modes
