Old 08-26-2013, 03:43 PM   #1
S10Fan
Old Heap Driver
Sealing an AD windshield
OK, so I've ordered new windshield glass and seal, how do you guys seal yours?
Any sealer around the glass?
Just seal the outer rubber against the cab?
Thanks!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-26-2013, 08:32 PM   #2
S10Fan
Old Heap Driver
Re: Sealing an AD windshield
............or just let a glass shop seal it?
Bryan
Old 08-26-2013, 11:44 PM   #3
msaintg
msaintg's Avatar
I did not add anything to the rubber seal. worked fine.
msaintg is offline   Reply With Quote
Old 08-27-2013, 12:28 AM   #4
NEWFISHER
NEWFISHER's Avatar
In the rainy NW I sealed the glass to the rubber seal and sealed the rubber seal to the body. I started out dry and chased water leaks when it rained or when I washed it until I finally sealed both.
NEWFISHER is offline   Reply With Quote
Old 08-27-2013, 08:53 AM   #5
focusedontheprize
focusedontheprize's Avatar
This is what I will be doing. The seal sealed the windshield great, except for a few places. For the extra insurance, I will be doing the above.
focusedontheprize is offline   Reply With Quote
Old 08-27-2013, 12:25 PM   #6
chev3600
chev3600's Avatar
Permatex makes a flowable windsheild sealant thats great for after installation. It's clear and seeps into the spaces/gaps, then gels.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 08-27-2013, 03:15 PM   #7
54 jimmy
54 jimmy's Avatar
I had sealed my windshield with windshield urethane. I did this after it was in and set.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-28-2013, 06:17 AM   #8
S10Fan
Old Heap Driver
Thanks for the replies. I think I'll have a local glass shop seal it after the install. My current glass (original but foggy edges) and new seal leaks like a rain storm, top middle and outer lower corners, even after many attempts to seal it.
I'll install my new rubber and glass then let a shop handle it. By the time I spend 20-25 bucks for sealer, several more dollars for a good caulking gun, I could have paid someone that knows what they're doing to do it right.
Bryan
Old 09-04-2013, 12:23 PM   #9
msaintg
msaintg's Avatar
I got caught in a monsoon storm last week and my windshield leaked at the bottom corners. I got some clear silicone caulk at Lowes (in the toothpaste tube, no caulking gun required). It was actually very easy to push the tip all the way down in the 'H' groove and fill it with silicone. Any silicone tha may have squirt out was easy to clean off with a plastic putty knife. Can't see anything now that it is dried. I put the garden hose on it today. Sealed great.
Old 09-22-2013, 11:48 AM   #10
S10Fan
Old Heap Driver
I finally got around to installing the new windshield/seal. First of all, my new glass arrived from Classic parts 8/30, I didn't open the box until yesterday, 9/21 to set the seal in the hot sun. This morning I discovered one of the panels is cracked. I suspect it was cracked before shipping, no damage to the box, no damage to the bubble wrap, plastic wrapper around glass had a major rub mark where the crack originates. Anyway, I emailed Classic this morning I'm sure they will take care of me.
I had already cut out my old gasket and removed the glass before the above discovery. (I know, stupid me) Didn't matter, my glass needs replacing. But, I'm glad things worked out like they did. The old gasket was from LMC and the windows dropped right in place, probably why they leaked, leaked really bad. The replacement gasket from Classic looked different, better, more beefy. So, with a friend helping me we reinstalled the old glass so my truck can be used this week. We like to never got the windows back in, took an hour at least. This new gasket lays out on the opening way better than the old one.
Yes, lots of soapy water, rope, plastic pry tools, several cases of 4 letter words, you name it. When the new glass finally goes in this week, today's experience will keep us from busting the new glass. I have a feeling the new gasket is going to seal just fine.
Bryan
Old 09-23-2013, 05:17 AM   #11
msaintg
msaintg's Avatar
Brian,
Are you putting the rubber in the frame and then putting the glass into the rubber? Or are you putting the rubber on the glass and then setting it in the frame? I ask, because the latter (glass in rubber, then rubber in frame) is WAAAAAAY easier. It only took me a few minutes to drop in the windshield that way.
Old 09-23-2013, 05:48 AM   #12
S10Fan
Old Heap Driver
Glass in the rubber then installing the glass/rubber combo into the window opening. The "new" rubber is 1/4-3/8" wider on the outside. The portion that goes inside the opening is a much tighter fit and required a lot of gentle persuasion.
The difference between the old, LMC and new, Classic, is night and day. With the old gasket a simple wash job left my dash and floor soaking wet. I'm really pleased with the new gasket and how I believe it will seal. I just need a new glass panel so this project can be finished once and for all.
Bryan
Old 09-24-2013, 05:57 AM   #13
msaintg
msaintg's Avatar
OK, cool.
I got my glass and rubber from Classic parts also. It seamed really tight enough, and it was fine in light rain storms. I still got water coming in when I hit a monsoon storm though, so I went back and added clear silicone between the glass and the gasket and gasket to frame and all problems are gone now. Gook luck installing yours.
Old 09-24-2013, 06:22 AM   #14
S10Fan
Old Heap Driver
Originally Posted by msaintg View Post
OK, cool.
Thanks.
Out of curiosity I'm going to leave mine unsealed at first, but I plan to have a local glass shop seal it later. Besides, I'm planning to use so much soap it may be weeks before it all dries up. LOL. A local glass shop said they would seal it for $20.00.
BTW......Called Classic yesterday and they're taking care of me but the windshields are on back order. I'm going to have a local shop cut me a replacement and just take the refund from Classic.
Bryan
Thread Tools
Display Modes
