Old 08-26-2013, 11:31 PM   #1
Kaotik Kustumz
Kaotik Kustumz's Avatar
Question ? bout 2.5" drop spindles....
ok everybody as yall might know im in the process of dropping my '86 chevy lwb 4.5"/6"....
right now i got the stock coils cut (1 full coil) and was needing to know that if i run 2.5" drop spindles if they will make my stock 15x8 rallies come in contact with any of the steering or suspension parts????
i was told that they will hit casue they backspacing...
so anyway i would like to know now BEFORE i spend the cash on them....
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Kaotik Kustumz is offline   Reply With Quote
Old 08-26-2013, 11:35 PM   #2
jjzepplin
jjzepplin's Avatar
Re: ? bout 2.5" drop spindles....
Me too as I am planning the same thing.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-27-2013, 01:33 AM   #3
nheller76
nheller76's Avatar
A guy on hear (79 blue monster) has 2.5 drop spindles and a cut coil and he isn't having any problems. See if u can read his build and u should get the answer.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-27-2013, 01:46 AM   #4
Hook0215
I did hzave a problem clearing stock rallys. Spindle rubbed wheel.
Hook0215 is offline   Reply With Quote
Old 08-27-2013, 03:52 AM   #5
cleansquare
Subbed for pics
cleansquare is offline   Reply With Quote
Old 08-27-2013, 06:10 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes.
You will need to trim the lower a-arm around the lower ball joint.
This has been documented many times on here concerning 15" wheels,... with more than 3.5" of backspacing.
Keith
Convert to disc brakes.
Old 08-27-2013, 12:00 PM   #7
DREAMER1
DREAMER1's Avatar
A quik grinding to the lower control arm will fix it.
DREAMER1 is offline   Reply With Quote
Old 08-27-2013, 04:08 PM   #8
bbbc10
Diggin The SquareLife
I have 2.5" spindles an have no problems
bbbc10 is offline   Reply With Quote
Old 08-27-2013, 06:11 PM   #9
lolife99
lolife99's Avatar
What backspace 15" wheels do you have?
Keith
Old 08-27-2013, 06:33 PM   #10
bbbc10
im running the stock 8" rallys so whatever bs they are
Old 08-28-2013, 09:33 PM   #11
MHarvey
I'm in the process of building the chassis for my 86 swb truck. I had planned on running the stock rallies for awhile after cleaning them up, but found that they hit on my McGaughy's 2 1/2" drop spindles where the tie rod end goes through the spindle. I put a 5/16 spacer on them for now so that I can get the chassis rolling, but would want longer wheel studs if I was going to drive it that way as there is not much thread engagement with the stock studs. This part of the spindle isn't very thick, and even if it was clearanced, it would hit the tie rod end itself on the dust boot, so no clearancing will work. They hit right on the inside edge of the rim where the wheel weights would be.
MHarvey is offline   Reply With Quote
Old 11-09-2013, 09:51 AM   #12
carolinasled
carolinasled's Avatar
I just installed some McGaughys 2.5" Spindles last night and the tie rod portion is hitting the weights on the Summit Racing 15x8 Rally wheels. I'm Gonna run spacers until I get the wheels balanced again and see if they can mount the spacer on the inside of the wheel.
carolinasled is offline   Reply With Quote
Old 11-09-2013, 10:12 AM   #13
I have been told it depends on which brand spindle you run. The folks that run the Bell techs and Western spindles don't seem to have clearance issues with the stock 8" ralleys (4" backspace). Those that run DJM and some others brands tend to have clearance issues with 15" wheels. IT depends on the wheel and backspacing. Some have to grind the caliper, some have to clearance the tie rod mounting point.
Old 11-09-2013, 10:55 AM   #14
Moloko
Hoarding Rusty Objects
Moloko's Avatar
Put Mchaughy's or however you spell it drop spindles on a guys C10. Stock rally's hit the lower ball joints, it needed wheel spacers. Also had to modify the stock brake hoses (had to bend the metal portions) for the hose to clear the upper control arm.
1985 Chevrolet K20 Silverado
1994 GMC Yukon
Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks
Moloko is offline   Reply With Quote
Old 11-09-2013, 11:17 AM   #15
baclay9
I ran western chassis and didn't have any issues with stock rally's.
baclay9 is offline   Reply With Quote
Thread Tools
Display Modes
