'67 Dex-cool or Not
Just got my first Vintage Chevy Truck!!
![]() Join Date: May 2013
Re: '67 Dex-cool or Not
flush it well
put a 180 thermostat in it and fill with the green stuff Thats what I would do , if its a small block , ls engine I would use dex cool |
Welcome to the forum. What motor do you have?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Thanks guys. Spent most of the day figuring out what engine is in it, it's a '72 or '70 350 (3970010 and front stamp has TAX suffix), has headers with duel Flowmaster exhaust and a Mallory ignition box mounted on the firewall. Don't know much else, bore, heads, cam...
![]() Join Date: Nov 2012
I would stay away from dex-cool. We have a fleet of GMC's and they came with dex-cool from the factory running LQ4 6.0 engines. We run power take offs with 1500RPM idles, and found our radiators clogging constantly. We switched to the green and stopped having problems. Prestone only!
![]() Save a few bucks on antifreeze and pay lots later with rust and repairs. I've never had a problem with prestone green, but every other type I've used or had used on trucks I service, ended up with rust or clogs. I've seen f~rd 300 6's rust right through the block because he insisted on saving a few bucks on antifreeze. ![]() Some people you can't help... spend a dollar to save a dime.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
Dex-cool is crap....stay away from it.....it eats gaskets. Run the green stuff or the (green) stuff that is compatible with both types.
#7 | |
Cluster King
The orange you are describing may also be sand in the casting. Some blocks did not get rinsed well from the factory and had some casting sand stuck in between the coolant jacks in the block. This was more of a common problem in the late 70's early 80's engines.
If it is casting sand, it can take forever and a Sunday to get it out. It only takes a little to turn green anti freeze orange. If the coolant test OK and you are not overheating, then I would not worry much about it. I also agree that dex-cool is not cool ![]() Good luck. |
I think Dex-cool is one of the greatest products ever invented ... for making slimey mud. My wifes Grandprix came with Dex and I didn't know it needed to be changed every so often. I guess it breaks down.
Now I can't make the brown crap go away, even after flushing 6 or seven times. Just like a bad toilet. ![]() |
Dex-cool and many of the new "universal" antifreeze packages use organic acids as inhibitors rather than alkalines as used in traditional green antifreeze. IME these inhibitors do not like to be used in systems with different kinds of metal present. Any time an acid is present in a tank with dissimilar metals, a battery is formed and electrons start to flow from one metal to the other. And even though GM and Texaco say Dexcool is safe, I always use green antifreeze with distilled water in my own vehicles.
#11 | |
Still plays with trucks
Dex-cool is nasty stuff. Stay away from it at all costs ![]()
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Thanks for all the input guys! I've raced motocross most of my life and have have never had any problems with Green antifreeze either, and all my race bike had aluminum radiators... I'm going with the "Old School Green!!" Love my new Chevy!!
#13 |
Re: '67 Dex-cool or Not, New question
During the flush, I was running water through the engine with the garden hose with the top radiator hose off to watch for clean water and it stopped flowing after about 2 min. Not running a thermostat for the flushing... Fan was turning the whole time... Is my water pump not working all the time??? I killed the engine for a min and it was flowing again when I fired it back up. What would cause that stopping in water flow??
Posted via Mobile Device |
#14 |
Moved new question to a new thread. Thanks guys!!
Thread Tools | |
Display Modes | |
