08-29-2013, 12:35 PM | #1 |
Bagged with stock floor and inner fenders
Does anyone have any pictures of c10s on air with stock arms and trailing arms with a bolt in notch and inner fenders with 16 inch steel wheels ..... Or something similar?
Posted via Mobile Device |
08-29-2013, 08:51 PM | #2 |
Re: Bagged with stock floor and inner fenders
If you use a notch, your bed won't clear the rear differential when aired out. I have 17" steelies, and 2.5" drop spindles.
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
08-29-2013, 08:55 PM | #3 |
Truck looks awesome .... Do you have a bolt in notch at all ? Got another picture from the side ?
08-31-2013, 06:02 PM | #4 | |
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
08-31-2013, 06:38 PM | #5 |
I have the Porterbuilt bolt in notch. My bed floor is slightly raised. My stock inner fenders are out right now because I'm painting them, but they do clear. Tire height is crucial. Mine are 27" tall. Here is a side pic.
07-12-2015, 09:48 PM | #6 |
Anyone else?
07-14-2015, 08:50 PM | #7 |
1972 Driver SOLD |
07-14-2015, 09:20 PM | #8 |
I am running the same wheels as cubber. I am on air, 2.5" drop spindles, no notch just yet. Going to put my notch in next week, but here is how it sits right now. I'm also going to install 2" drop blocks in the rear to help even out bag pressures.
James
'64 C10 Build Officially LQ/NV3500 swapped and Bagged |
07-15-2015, 09:30 AM | #9 |
Cubber what rims are those?
07-15-2015, 10:44 AM | #10 |
Scratch that. I thought they were the same as mine, but I am seeing a stepped lip now. Maybe one of the Summit wheels?
James
07-15-2015, 09:26 PM | #11 |
A few aftermarket companies make rims that style was wondering how he got the center caps to fit.
07-16-2015, 06:51 AM | #12 |
Kill Bill...et
As said previously. As long as overall tire diameter is roughly 27", you'll be solid. Inner fenders installed, bolt in notch, bed raised 2" Crossmember sits on the ground as the tires rest on inner fenders.
07-17-2015, 03:42 AM | #13 |
DANG that's a beautiful truck.
1972 Driver SOLD |
07-20-2015, 07:34 PM | #14 |
Happy to be here
This is as low as you can go with out cutting the bed out. N2billet did modify the inner bed sides, but the tubs are stock.
07-20-2015, 08:42 PM | #15 |
Man that's a nice truck
07-22-2015, 09:27 PM | #16 |
Stock inner fenders bed floor and small cnoth this is the lowest you can go with 20's all around
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-05-2015, 04:01 PM | #17 |
This is great information, what wheel width and offset are you guys running on your wheels? And are your tires tucking inside the fenders or on the 1st couple of inches of the outside where it's flat?
10-06-2015, 12:16 AM | #18 |
This is about as low as it can go on mine. Stock inner fenders with about 1/2" clearance at top, stock bed height with 1/4" clearance at top of diff., 20" wheels, 28.7" tall tires, porterbuilt bolt in c-notches, porterbuilt mild drop member with 2" drop spindles.
If I raised the bed a bit, the back could drop another 1.5", and remove the inner fenders would probably get another 1.5-2" drop. Don't have any new pics yet with the hood and bumper on, but they are on.. |
10-06-2015, 12:58 AM | #19 |
Beautiful truck! I really like the pro touring style. Thanks for the info. Are you bagged?
10-06-2015, 01:47 PM | #20 |
10-27-2015, 08:19 AM | #21 | |
What bump stops are you using?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
10-27-2015, 09:43 AM | #22 |
Rear bump stops came with c-notches, for the front I have QA1 shocks and the bumps slide on the shock piston, just cut to length you want.
10-27-2015, 01:38 PM | #23 |
DO you have a part number for the shock style bump stop? I like that idea.
Thread Tools | |
Display Modes | |
