Old 09-01-2013, 08:08 PM   #1
lt1tyrell
Inline 6 headers
Hey has anybody used the tube style headers like hedman makes for these engines? I would like the Langdon split manifolds but the Herman's are alot cheaper. The only think I do t want is cracked, leaky headers, that drives me nuts. So let me know what you guys think because if I will have problems with the hedmans I will pay extra for the cast iron split manifolds, thanks.
lt1tyrell is offline   Reply With Quote
Old 09-01-2013, 08:13 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Inline 6 headers
Just curious. Are you putting the headers on a 230 or 250 or ???????
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-01-2013, 08:22 PM   #3
Sharps40
Steel tube hedders may leak/crack and they do rust thru occasionally and do increase temps in the engine compartment.
Cast Iron headers (langdons version fits 194/230/250/292) are less leak pron, less likely to crack, rust thru about as often as a factory iron manifold - rare, and likely raise the under hood temps a bit but not as much as tube headers.
Both are a compromise as they require more complex exhaust bending and both will require you plumb either exhaust heat or hot water to the intake to retain starting and cold weather drivability at useable levels.
If its not a big mean hot six, the factory manifold with 2" single exhaust all the way back and a smooth flowing performance muffler will give you best bang for the buck.
Sharps40 is offline   Reply With Quote
Old 09-01-2013, 08:30 PM   #4
lt1tyrell
I honestly don't know if it is a 230 or 250, have not checked any ID numbers, it's a 66 c10
Old 09-01-2013, 08:32 PM   #5
Sharps40
From a standpoint of installation of headers the CU IN dimensions probably won't matter. I believe all the exhausts are the same on at least the 194/230 and 250....pretty sure the 292 exhaust manifold is same too.
Old 09-01-2013, 08:33 PM   #6
lt1tyrell
Great info, thanks. I will prob use the cast iron split setup then because I really like the look and sound, a little extra power is nice but I don't expect crazy power from a warmed up 6. I just like the fact that they are unique.
Old 09-01-2013, 08:36 PM   #7
Sharps40
Actually, headers alone, can add 10 to 25 hp and equivalent torque in the useable ranges of the power band to a factory six in good condition. A lot depends on how you plumb it. Intake and igniton are also part of that overall equation. If you go over 2" on duals, you push all of your gains out the tail pipes in the form of not enough restriction....might even lower the numbers the motor is capable of. If you go Langdon iron headers talk to tom before you buy and start bending pipe. But, yer gonna have ta figure out what motor for him to give ya best advice.
Old 09-04-2013, 10:26 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
On my 292 of used Clifford's 16 gauge tube headers. They are great! I went with a dual 2 1/4 inch pipe to dual flowmaster 40 series, but I have and hei and a 600 cfm edelbrock 4 barrel on it. The motor is stock except for those updates and it runs great. Has plenty of back pressure, and pull long and hard. If you are gonna buy an intake I would get the clifford version and mount something no larger than a 390 holley unless you are going to do some head work and cam it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-04-2013, 11:34 AM   #9
tincan1966
tincan1966's Avatar
I ran the Hedman split headers on my last '66GMC w/ 250. No adverse effects, ran great no leaks. I used a good gasket, not the paper one that comes with them. Ran dual 2 1/4" straight pipes(no mufflers) exited at a 45 degree in front of left rear wheel.
Any header is going to out flow and perform better than the stock manifold.
tincan1966 is offline   Reply With Quote
Thread Tools
Display Modes
