09-02-2013, 04:39 PM | #1 |
What is my correct carb??
after replacing the fuel tank, fuel pump, lines and sending unit I
noticed that my rochester started leaking pretty bad from the fuel bowl. I put a ton of plumper's dope on the nut threads but it just wont quit leaking, it seems that the larger nut that goes into the fuel bowl will not seat... it just keeps spinning.. after looking at the threads in the fuel bowl i decided a new carb might be in order.. the threads are pretty much shot and a new carb is not a huge investment,... so after taking the id numbers off the carb I have come to find out that the carb came off a 73 .. the carb id is as follows 704314 (build code of 171 3a).. I would rather buy the carb that orginally came with my motor.. so anyone have an idea what should be on a 68 gmc 2500 6cyl 250?? The intake seems to be orginal and the build date on the motor looks to be the right motor.. just want the proper carb.... help and suggestions appreciated
68 GMC 2500 stepside LWB 250CI |
09-02-2013, 06:08 PM | #2 |
Re: What is my correct carb??
You might be able to fix that spinning inlet fitting with one of these. Better than changing out the whole carb.
http://quadrajetparts.com/rochester-...ng-p-1071.html And JFYI don't use t-tape on flare fittings. Last edited by geezer#99; 09-02-2013 at 06:13 PM. |
09-02-2013, 09:40 PM | #3 | |
09-02-2013, 09:42 PM | #4 |
Maybe these 2 links will be helpful to narrow down the correct carb
http://www.carburetor-parts.com/Chev...ck_ep_419.html http://www.teufert.net/carbs/truck.htm |
09-02-2013, 11:45 PM | #5 | |
those links helped a bunch.. thanks for the knowledge base. Posted via Mobile Device
Thread Tools | |
Display Modes | |
