Old 09-03-2013, 04:33 PM   #1
t300
limit straps for airbags?
How many of you here use limit straps for your airbag installs? I'm actually not concerned with limiting out the bags or shocks when driving as I can't really see that happening, but more so I'm concerned with pulling the bags apart when putting the truck on a hoist. I have a drive-on hoist but its going to a shop shortly for a government mandated 'safety check' before I can get permanent tags on it, and they only have a 2post.
I am running SS7 bags, ECE rear shock re-locators and kyb shortened shocks from ECE. I haven't 'tested' to see if the shock limits out before stretching the bag too much. thoughts?
thanks
t300 is offline   Reply With Quote
Old 09-03-2013, 04:50 PM   #2
SCOTI
SCOTI's Avatar
Re: limit straps for airbags?
I know I've read of some straps being used. I've seen SS cable cut to length w/crimped barbs to secure the loops & they were bolted to the frame/bag mounts. Another similar set-up used the nylon straps for tying down a vehicle on a trailer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2013, 06:20 PM   #3
Pro Performance
Pro Performance's Avatar
Whenever I lift my truck up to work on it, and the suspension is drooped all the way down, I just leave about 10-15 PSI in the bags. This keeps them from stretching and pulling the rubber in an odd way. It keeps the bag round.
- Travis
Pro Performance is offline   Reply With Quote
Old 09-03-2013, 11:11 PM   #4
baclay9
Glad to see this come up as I had concerns about this.
baclay9 is offline   Reply With Quote
Old 09-04-2013, 10:42 AM   #5
broey
Square
broey's Avatar
its not really a concern. if you run shocks with a same stroke as your bags then you already have a limiter. but, your bags can handle being stretched. ALL BAGS will get small cracks around the cups when they hang and it is totally normal. they still have the radial woven between the rubber for support. I wouldnt leave the truck up in the air for days at a time without supporting the axles but it will be perfectly fine during inspections.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 09-04-2013, 04:10 PM   #6
SCOTI
SCOTI's Avatar
I've always heard the sleeve/rolling sleeve type bags cannot be over extended or they'll fail.
The key thing to consider is failure from over extension might be dependant on the type of bag. Always check w/the manufacturer for their recommendations....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2013, 04:23 PM   #7
Ziegelsteinfaust
On sleeve bags for overload set-ups only bolt to the frame, and use a c channel to slip over the leaf.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-06-2013, 04:26 AM   #8
wraprail
wraprail's Avatar
I have firestone 9000s in the rear and made sure when I built it that my shock mounts were such that the shocks would limit the bags from over extending. You need some kind of limiter with a sleeve bag
wraprail is offline   Reply With Quote
Old 09-06-2013, 05:12 PM   #9
t300
thanks for the feedback guys~
Thread Tools
Display Modes
