![]() Join Date: Jun 2011
engine swap
I am wanting to pull my 350 out of my 69 and replace it with a 402. will I need to change motor mounts or will the 402 bolt right in?
Moderator
![]() Join Date: May 2007
Re: engine swap
You could probably make them work...but it won't "bolt right in". If you are picking up a 402, get all the accessories that you can with it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: engine swap
what am I going to have to do to bolt it in? 402 came complete with ac and turbo 400
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: engine swap
You need the mounts too. The big blocks had a droop in the frame mounts that allowed manifold clearance that the small block frame mounts don't have. If you use small block mounts you're not going to be able to find a manifold or header that clears them.
Posted via Mobile Device |
Re: engine swap
thanks for the help. looks like im looking for mounts now.
Thread Tools | |
Display Modes | |
