09-07-2013, 12:35 PM | #1 |
need help engine id
I have a small block chevy can't see number to decode it, today I bought some valve cover for 307 which I think it is? New valve cover the holes for bolts are even on both sides, the old ones are off set on the one side... So what size do I have?
09-07-2013, 12:45 PM | #2 |
Roadtrip!
Re: need help engine id
Hard to say without any casting numbers, but the staggered holes were late 50s- early 60s.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-07-2013, 01:18 PM | #3 |
The Corvette world says the staggered bolt heads were used until early 1959 on the 283s. I imagine the earlier 265s also used staggered bolt heads. There were no emissions of any kind on these engines. Your valve cover has been modified for emissions. My guess you have a later SBC block with 283 or 265 heads.
09-07-2013, 02:59 PM | #4 |
Hi!! you should see this http://www.fastnuf.com/Headguide.html . Look at the front of the head, there is a geometric pattern, then compare it to the image on the page I post, and at least you will see which heads are on your engine
Thread Tools | |
Display Modes | |
