Old 09-09-2013, 11:50 AM   #1
davidcollier
Fuel line on lmc tank ?
Ive installed a lmc tank under the bed . Im not real sure where to run the fuel lines to . The truck didnt have a fuel tank in it when i got other than a 5 gallon bucket in the bed . I know the one from the sending unit goes to the carb . but where does the other line from the tank go ?
davidcollier is offline   Reply With Quote
Old 09-09-2013, 08:17 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Fuel line on lmc tank ?
Unless you have a return on you fuel pump the other outlet is a vent. I ran a hose up inside the bedside and put a filter on the end. You can also vent to the filler hose if you have a connection there. Not sure how you are planning on filling.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 09-09-2013, 08:53 PM   #3
swamp rat
swamp rat's Avatar
Yep, my fuel cell has a vent tube and has a one way check valve required by law in case of a roll over crash, the other to the fuel pump. I put a filter on the end of my vent tube and mounted it up above the tank.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-10-2013, 11:09 AM   #4
davidcollier
Thanks guys
Thread Tools
Display Modes
