Old 09-09-2013, 03:58 PM   #1
68Stepbed
68Stepbed's Avatar
Question for Rob@NoLimit
Actually anyone can answer this, but this is in referral to Rob's shock mounts.
Would it be beneficial to mount a set of coil overs in the same position as these shock relocators from No Limit?
Now, I know they would need to be built a little better with captured bolt positions for added strength of the spring and weight, so my main question is about the position.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-09-2013, 06:29 PM   #2
SCOTI
SCOTI's Avatar
Re: Question for Rob@NoLimit
I tried talking Porterbuilt into building his T/A's w/this optional mounting position for coil-overs before he started regularly marketing them a couple years ago. My thought was to keep the C/O as close to the frame as possible for max tire clearance while keeping the 'springs' as far outboard as possible for improved stability (vs the typical inside the frame rails arrangement).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-10-2013, 12:11 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Scoti... I really was listening! LOL
We are actually making an option. It will be available to be used with our trailing arms, and we will also be making one to work on a factory trailing arm.
To answer your question 68Stepbed this set up will work nice. You may want to set the coil-over more upright than the shock in the pic.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-10-2013, 12:42 PM   #4
SCOTI
SCOTI's Avatar
Nate
I never doubted you briother.... never (you listened on the sphereical bearing vs poly bushing)
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-10-2013, 03:08 PM   #5
68Stepbed
68Stepbed's Avatar
Nate
Do they need to be completely vertical or can they tilt inward some?
Matt
Old 09-10-2013, 03:20 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
They can tilt inward some.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-11-2013, 09:45 PM   #7
Wild83C10
Wild83C10's Avatar
Here's how I did my C/O setup with trailing arms. I used standard C/O weld-on tabs/brackets by competition engineering. I have allowed for the maximum wheel space as well as the optimal spring position.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-13-2013, 12:11 PM   #8
robnolimit
robnolimit's Avatar
The current mount in single sheer is not up to the task. We used to make a set of mounts for coil-overs similar to these. They worked great but I think we were way ahead of the market. Again, the trick here is shock length. A short shock will drop the truck, but have less travel and require a stiffer spring. = bad ride. A longer shock, say 5" or 6" stroke will offer more travel, and allow for a softer spring rate = good ride, but, this won't drop the truck as much, so you need to add in a 2" block. Or, if you are raising the bed floor you can raise the upper coil over mount.
BTW, do yourselves a favor. Stop with the step notching. If your going to raise up part of the rail for axle clearance, then man up and raise the rail. This way you have more room for suspension, exhaust, fuel tanks, battery...... just my $.02
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Thread Tools
Display Modes
