09-11-2013, 01:35 PM | #1 |
Question about sway bars
I have seen several sway bars here for sale and have tried to buy some but I wasn't quick enough. So yesterday I'm walking around in my local pull a part and low and behold I find a 70 c10 with a sway bar. I got the bar but the brackets that attach to the frame are riveted so I had to leave them. It got me thinking, the bars I've seen here for sale, I don't remember seeing the frame brackets included so what are these guys who buy the bar doing for brackets?
Where can I get these brackets??? I may have to go back to the yard with power tools and drill the rivets. Posted via Mobile Device |
09-11-2013, 01:43 PM | #2 |
Re: Question about sway bars
LMC sells the brackets.
Part # 34-2524 Price $27.95 Page 138 of the catalog. |
09-11-2013, 03:07 PM | #3 |
early classic enterprises has them too. your bar will either be 1 1/16" or 1 1/4". measure the diameter and order accordingly. ece also has the bushing mounts for a lowered truck....
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
09-11-2013, 03:14 PM | #4 |
I bought a used sway bar off the board and it came with all of the brackets.
It looks like the LMC brackets are for a lowered truck, so they're shorter than the stock height. I don't know if using lowered brackets would make any difference on a stock height truck.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
09-11-2013, 03:25 PM | #5 |
Any sway bar will work up into the 80's trucks
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
09-11-2013, 03:47 PM | #6 |
I am a Referee of life.
You can get frame brackets for either thru CPP.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-11-2013, 04:42 PM | #7 |
I used a battery powered hack saw to cut the heads off the rivets, and pound them out with a hammer. About all you can do in the junk yard.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-11-2013, 05:40 PM | #8 |
70+ ( Old Skool Club )
I'd recommend getting new brackets, the ones for lowered trucks, with the polyurathane bushing. I've heard people on here say the poly bushing squeak but I have had my 1 1/4" bar with the lowered brackest and poly bushing since 2005 and have never heard a squeak. I used the lube that came with the ECE brackets for lowered trucks. You will love the difference in the handling of your truck once you get the sway bar installed. My truck is not lowered but I installed the lowering brackest because I like the fact that you can't see the sway bar unless you are on your hands and knees looking up under the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-11-2013, 08:00 PM | #9 |
Thanks guys! ECE, is that Early Classic Enterprises? Are the brackets closer to the frame for lowered trucks ?
09-11-2013, 08:21 PM | #10 |
My truck has a front sway bar with the lowered truck brackets andcas you can see it is not visible. ECE is Early Classic Enterprises.
09-11-2013, 09:10 PM | #11 |
Watch out for your cornhole !
Everything you need to know. I wrote it ten years ago so some of the prices are a little low nowadays, but the pictures, procedures, and part numbers are still good.
http://www.67-72chevytrucks.com/vboa...hlight=Swaybar Posted via Mobile Device |
09-12-2013, 11:01 AM | #12 |
Excellent write-up Tx Firefighter! Everything I need to know and more, thanks!
Thread Tools | |
Display Modes | |
