Old 09-17-2013, 12:57 PM   #1
In The Ten Ring
What do you do to inner fenders?
I have a set of inner fenders I may put on my truck. They are from a 1967 (my truck is a 1972) but people on this site say they'll fit.
What do you guys do for inner fenders (the undersides)? Powder coat or paint and why?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 09-17-2013, 01:14 PM   #2
JointTech
JointTech's Avatar
Re: What do you do to inner fenders?
bedliner or undercoating is what I usually see.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 09-17-2013, 01:31 PM   #3
Mister-B
This is what I used. It went on easy, and is holding up well
Mister-B is offline   Reply With Quote
Old 09-17-2013, 01:31 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Flat black paint works well.It's easy to touch up.I think the ones I'm putting in the panel will get coated with DIY bedliner.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-17-2013, 01:48 PM   #5
hfd410
hfd410's Avatar
i painted mine with rustoleum semi gloss black through a gun. worked good
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 09-17-2013, 03:29 PM   #6
oleguy
I've used rustoleum semigloss black on frame and inner finders, and under the hood for many years with vary good results. I always use the rustoleum rusty metal primer, it used to be called damp proof primer. I use a spray gun. Flat black doesn't clean well, and gloss is to shinny and doesn't touch up well.(MY OPINION ONLY)
oleguy is offline   Reply With Quote
Old 09-17-2013, 04:16 PM   #7
wreckedchevy
wreckedchevy's Avatar
i'm going to try the majic implement high gloss black. suppose to be really tough paint. haven't picked out an under coating to use i'm looking around at some different brands of bedliner.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 09-17-2013, 04:56 PM   #8
In The Ten Ring
Well I bought this rust inhibitor in a can from NAPA just now and a NAPA brand of rubberized undercoating, also in a can. I want to spray the frame where my cab mount bushings go and then paint. The undercoating I'll try out on the underside of the inner fenders.
I found a local place for sandblasting and I might get them to clean things up and then me just spray this stuff on.
Old 09-17-2013, 06:11 PM   #9
wreckedchevy
this is the majic implement paint on my frame horns looks like powder coating very nice finish on it for 12.99 a quart and you can brush it on. just did my battery box and bumper bracket's as well looks really good.
Old 09-17-2013, 06:16 PM   #10
In The Ten Ring
Oh boy, that does look nice! I may look into that stuff.
I bought a can of NAPA "Rust Inhibitor" and NAPA "Heavy Duty Rubberized Undercoating." I haven't tried either.
Old 09-17-2013, 07:31 PM   #11
bigmac73
bigmac73's Avatar
i scuffed them up with a green pad, then used POR-15 on both sides and topcoated with glossy black rustoleum, my whole engine compartment is POR-15 then top coated with rustoleum
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-17-2013, 07:40 PM   #12
brian1971
brian1971's Avatar
WreckedChevy did you brush that on your frame horns looks really nice,Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 09-17-2013, 08:17 PM   #13
swamp rat
swamp rat's Avatar
Rust inhibitor..... some kind of phosphorous acid? turns black as it dries..
Be sure to wire brush and or sand as much as you can forts.
Be sure to post a pic of the undercoating if ya would.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-17-2013, 08:20 PM   #14
tlcrz1972
tlcrz1972's Avatar
I used a product called rocker guard, IDK is it's still available but 18 years and 78,000 miles later it is still great.
It takes a beating from rock thrown by the tires.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 09-17-2013, 08:22 PM   #15
In The Ten Ring
It may be a sort of acid as the label (and NAPA clerk) did in fact say, "goes on white and turns black as it dries." I expect to do the cab to frame bushing area of the frame with the Rust Inhibitor only and then paint over it.
I am still in the air about powder coating my inner fenders but will probably just use Rust Inhibitor and spray paint the tops and Undercoat the bottoms.
Old 09-17-2013, 08:47 PM   #16
Tinkermc
Wreckedchevy where do you buy it? Looks 2 good to pass up.
Tinkermc is offline   Reply With Quote
Old 09-17-2013, 09:34 PM   #17
mmiddle
mmiddle's Avatar
My plan is to powder coat them and then Camoliner the underside to a semi-gloss finish. The rest of the underside will be Camoliner in body color.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-17-2013, 10:03 PM   #18
EpicDH
Originally Posted by wreckedchevy View Post
Attachment 1153032
Where did you buy that paint....cant seem to find black?
EpicDH is offline   Reply With Quote
Old 09-17-2013, 10:29 PM   #19
mmiddle
mmiddle's Avatar
Tractor Supply I believe carries the Majic brand of paint
Mark
Jesus is the Way!
Old 09-17-2013, 10:30 PM   #20
swamp rat
swamp rat's Avatar
http://www.majicpaints.com/products/farm/tti/
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-18-2013, 12:11 AM   #21
wreckedchevy
yea I lightly wire wheeled the frame horns spayed them with the majic red oxide primer. then (the wife) brushed on the high gloss black with a $.99 cent foam brush.
Old 09-18-2013, 12:12 AM   #22
wreckedchevy
http://www.tractorsupply.com/en/stor...k-103095899--1
Old 09-18-2013, 03:34 AM   #23
BruthaMan
US Army Veteran
BruthaMan's Avatar
Chassis Coat by POR-15. Lined the bottom of my '78 with it. Tough as rocks.
BruthaMan is offline   Reply With Quote
Old 09-18-2013, 03:44 AM   #24
In The Ten Ring
Apparently, there are several ways to reach the same result! In fact, I've gotten so many replies and product reviews, I'm more confused than ever as to what to try! :-)
Old 09-18-2013, 07:16 AM   #25
bigmac73
bigmac73's Avatar
well i would go with what ever you can afford, the great things about our trucks, are if it dosent look good , you can always strip and redo with another product
Mike
Thread Tools
Display Modes
