Old 07-08-2003, 10:07 AM   #1
biglou55
68 rear end swap or conversion
I recently acquired a 68 longbed that came from cali. some one had changed the front end over to 5 lug power disc.what rearend will fit so i can put 5 lug on the back. it is 6 lug now. or what axles will interchange if i can get that lucky. it has coil springs THANK,S IN ADVANCE BIG LOU.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 07-08-2003, 10:12 AM   #2
raggedjim
raggedjim's Avatar
Easiest: rearend out of '71-72 chevy truck with coils
Not as easy: rearend out of 73-84 (will require cutting old brackets and welding)
Another way: pull the axles and have them redrilled for 5 x 5 bolt pattern (my uncle is a machinist and did this once for me, I also had to buy new drums for the rear)
Hope this helps, Roger
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 07-13-2003, 06:06 AM   #3
dapolice1
We can roll all Day!!
Does anyone know if you can get 5 lug axles for these designed to be used in a disc setup? Or if you can get the 5 lug drum axles for the 6 lug rear and get a disc kit for the 5 lug drum axles? Email me if you know dapolice1@ev1.net
dapolice1 is offline   Reply With Quote
Thread Tools
Display Modes
