09-18-2013, 09:28 PM | #1 |
2 Speed power-glide odd shifting.
Hey guys, have a 67 c10 with a freshly rebuilt 327 and it also has the 2 speed power glide tranny, the trans wasn't messed with when the motor was rebuilt.
I started noticing that while driving right before it shifts it acts as if its in neutral and the rpms go up then it seems to catch the gear and shift. Wasn't positive if it was due to the kick-down not being attached on the carb and perhaps its stuck or what the problem could be? any advice would help! |
09-18-2013, 09:38 PM | #2 |
Re: 2 Speed power-glide odd shifting.
I had a 65 impala when I was a kid. The glide did the same exact thing for awhile, then completely died. Sounds like a good reason to swap in a th350. You'll be glad you did!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
09-18-2013, 09:40 PM | #3 |
oh boy, i had a feeling it was going out......we got an extra trans with the truck but idk what kind it is, i guess ill have to get all the markings and numbers off it tomorrow.......but again idk the condition of that trans either.....
09-18-2013, 09:45 PM | #4 |
Slip-and-slide Power glide!
The kick down cable would not cause this. It sounds like a pressure problem. Ether the fluid is low or dirty or something is failing inside. Does a PG have a modulator? if so it could be the modulator maladjusted or failing. The modulator controls the line pressure.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
09-18-2013, 09:47 PM | #5 | |
09-18-2013, 10:48 PM | #6 |
I am a Referee of life.
If you have to replace the tranny,there's no reason to go halfway.Go ahead and upgrade to an OD.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-18-2013, 10:59 PM | #7 |
I don't believe Glides have modulators. (Edit-looks like earlier powerglides with cast iron case did indeed have a modulator.)
Run er till she blows!
71 K20 64 GMC mud truck Last edited by 71K20chevy; 09-18-2013 at 11:06 PM. |
09-18-2013, 11:05 PM | #8 |
Ya, Im not sure. I don't have any direct experience with them. I know they are great for drag racing....
09-18-2013, 11:20 PM | #9 | ||
Strange that it would be bolted to a low hp sbc |
09-18-2013, 11:31 PM | #10 |
Stick a magnet up to the case! (Not the pan)
If it sticks, you got a cast tranny. But I agree with the OD suggestion above, however...
71 K20 64 GMC mud truck |
09-19-2013, 06:25 AM | #11 |
1969 Custom 30 wrecker
I've had a couple powerglides do this. None of them died on my watch however.
The one car was a 68 Impala and the previous owner had it at transmission shop. They couldn't figure it out! ?? I put 38,000 hard teen age miles on it after that and it was still going strong when I sold it. It was annoying, I would just leave off the gas a bit while it was shifting to avoid the rev. My 66 Impala will occasionally do this too but not as bad.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-19-2013, 07:37 AM | #12 |
I'm hoping for you that it's just a fluid level issue. A year or so ago, I was fighting some significant leaks on my powerglide. Anyway, a couple of times I went to drive it and it would behave as you describe. I checked the fluid, which was a little low....added fluid and problem was solved.
I'm not claiming that you have a leak, but I'm assuming the radiator was pulled when the motor was taken out....meaning the transmission cooler lines were disconnected. Unless someone put in a PG from an older model, you should have an aluminum version. Also, the aluminum PG's do have a vacuum modulator. It's located on the drivers side at the rear of the transmission. Posted via Mobile Device
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
09-19-2013, 06:58 PM | #13 | |
got some pics of the extra trans we received when we got the truck, i believe its a 700-r4/4l60e |
09-20-2013, 03:58 PM | #14 |
Looks like you got a 'free' 700R4. Check it out, overhaul it, and run it. The PG problems you're experiencing are the same ones my '62 Chevy Biscayne did before the transmission didn't 'transmit' anymore. I never got a chance to fix it- parked it in front of my then-girlfriend's house (where it died) went out of town for a weekend (in her car) and a drunk neighbor hit it and totaled it- and her Lincoln, too. You'll like having OD, and there's plenty of info here on the board, and elsewhere.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
09-21-2013, 04:56 PM | #15 | |
09-21-2013, 08:54 PM | #16 |
Without opening it up completely, pulling the pan and looking for excessive debris and noting the fluid condition (clear red, murky brown, 'burnt' smell, just plain old ATF odor) can tell a lot about it. To be sure, drop it off at a reliable transmission shop (someone recommended by a close friend) and get it rebuilt- it won't cost as much as a new reman unit, and you know exactly what you've got. Those transmissions are pretty solid, but not without their weaknesses. A good rebuild can eliminate those shortcomings, and you'll have an overdrive transmission that is totally worth the effort and head and shoulders above a Powerglide- especially one that appears to be on its way out.
09-22-2013, 12:48 PM | #17 | |
If both hoses are connected, start engine with neop. hose loose at modulator. It should have good vacuum; if not, the upper hose OR the tube is not holding vacuum. Find leak and repair. Also possible, but less likely: If the kickdown linkage happened to get hooked into wrong hole in carb linkage, or maybe not hooked up at all, it COULD very well cause this so-called "overrunning" condition. Even least likely would be the linkage needs adjusting; but the engine repairmen would not likely 'screw' the linkage out of adjustment. Yet, linkage improperly adjusted could also cause this same condition. DO NOT TRY ADJUSTING EXCEPT AS A LAST RESORT--EVEN THEN, HAVE IT DONE BY A TRANS PRO. He'd probably charge only a few bucks--I've done all these repairs for free in the past, but was not mechanic'ing for a living at the time. Sam |
09-22-2013, 01:31 PM | #18 | |
feels like the hose isnt straight on but its on. When we put it together we werent sure/couldnt remember which bolt on the trans the tube and trans dipstick mounted to. tried both bolts for the tube and neither would give it an easy slide on connection..... |
09-22-2013, 03:34 PM | #19 |
well its all connected and whatnot....
09-22-2013, 08:14 PM | #20 |
Red line, vacuum modulator for tranny. You won't need this line for the 700R4.
Black line, looks like a plugged off vacuum hose for something else. Also looks like it could be eliminated. If you do remove them, be sure to plug the holes!
09-23-2013, 12:29 AM | #21 | |
425hp409
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 09-23-2013 at 12:54 AM. |
09-24-2013, 08:25 PM | #22 |
We reattached the kickdown and i drove it today and its still showing symptoms......am i to late?
09-24-2013, 08:28 PM | #23 |
wrong thread
Thread Tools | |
Display Modes | |
