Old 09-22-2013, 10:54 PM   #1
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Warning light gauge cluster refresh
So I removed my gauge cluster to day to check bad bulbs and such. I took the cluster apart, and was amazed at how faded and cracked the original warning light filters were:
Here they are held up to light:
I had a good read from the "How to restore and Detail and Original Gauge Cluster thread" found here. While I had it apart, I repainted the fuel and speedo needles that were faded. I painted them white then bright orange. I had the paint already for using on gun sights.
Heres the fun part. I looked around for translucent colored things to use as new filters for the warning lights. I found these clear colored folder things at staples for $5. They didn't have a dark enough orange, but the pack I bought had green and red (along with blue, purple and clear). I folded the folder to make three layers. Using the cardboard tubes that the filters mount to, I traced around the outside of the tube with a fine tipped marker. I cut the pattern out which gave me three pieces. I used three stacked together per cardboard tube to give a deeper color. I test fit the three pieces just into the rubber ring and trimmed away my pieces until they fit without being bubbled or wavy. Once satisfied, I put the cardboard tube back together with the rubber and the new filters. Mine were still lighter colored than the originals, but I like the look.
My truck is going to be mainly a daily driver/beater, so I didn't worry about the light rust on the speedo gauge or the scratched cluster lens. Maybe this will give someone some helpful tips or ideas.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 09-23-2013, 12:16 AM   #2
perro13
perro13's Avatar
Re: Warning light gauge cluster refresh
Looks nice % bright. Good job
perro13 is offline   Reply With Quote
Old 09-23-2013, 12:16 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Neat trick with the warning lights.
Looks good.
66 C20 Service Truck:
Old 09-23-2013, 12:26 PM   #4
theastronaut
theastronaut's Avatar
Looks good, I did the same thing on a couple warning light clusters. You're not too far away, I'm in Anderson/Belton.
theastronaut is offline   Reply With Quote
Old 09-23-2013, 02:27 PM   #5
ClemsonChevy
Wow, I didn't even notice your location when I was reading your thread!
95 2500 350 w/ 3.73
Thread Tools
Display Modes
