Old 09-23-2013, 09:53 PM   #1
deestrong71
deestrong71's Avatar
Traction Advice
Do any of you Bracket racers have any advice on how to get your Chevy to hook up.
Besides Tubbing, Ladder bars Etc..
Hope, Faith and Strength
**Deestrong**
deestrong71 is offline   Reply With Quote
Old 09-23-2013, 10:18 PM   #2
mmiddle
mmiddle's Avatar
Re: Traction Advice
If you have the swing-arm rear....New springs, good shocks and sticky tall tires. If you get up over 500HP you might want to box in the swing-arms or replace them with tubular models. Other than that, I've never had a problem.
Those long swing arms tend to flex with lots of torque, but they are basically the perfect set-up.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-23-2013, 11:43 PM   #3
Fitz
Re: Traction Advice
Since you are headed well north of 500HP it will take some time to get the rear set up. Try one of these in the bed over the rear axle:
Fitz is offline   Reply With Quote
Old 09-25-2013, 01:47 AM   #4
deestrong71
Re: Traction Advice
That looks like a big bladder you fill with water !
**Deestrong**
Old 09-25-2013, 07:59 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Traction Advice
Move the fuel tank,battery and anything else you can to the rear of the truck.Helper airbags in the coil springs may help tune the suspension.Strengthening the Trailing arms should help.
You might try bolting a tractor weight under the rear of the bed.It may be a trade off,more weight slows you down but the added traction may improve your ET.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-25-2013, 03:07 PM   #6
Lee H
Lee H's Avatar
Re: Traction Advice
How about these.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-25-2013, 07:48 PM   #7
Mike C
Mike C's Avatar
Re: Traction Advice
Drop the back more than the front. Add Cal-Trac bars if you are leaf spring rear and get some good adjustable shocks.
Reinforce the rear trailing arms and add a sway bar if you are coil spring. Get some good adjustable shocks.
Obviously the tires pictured above help in either scenario.
Replace engine with 307 like in my '69 short step. Traction problems no longer an issue for you.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-25-2013, 08:37 PM   #8
Fitz
Re: Traction Advice
Yes, 300 pounds of water right over the rear axle. That and reinforcing your trailing arms and stiffer springs will help it hool but there isn't much you can do until you fix the fender well width so you can run some wide rubber.
Old 09-25-2013, 08:55 PM   #9
mmiddle
mmiddle's Avatar
Re: Traction Advice
As you can see, with the trailing-arm rear, there really is not much you need to do until you pass 500hp. It is a truck and it is light in the rear that will be your biggest obstacle.
Now if your going for a race only truck you can push the engine back a ways.
Mark
Jesus is the Way!
Old 09-25-2013, 09:05 PM   #10
grancuda
grancuda's Avatar
Re: Traction Advice
Make sure back end is set up right like above posts.
Move the motor back to the inline 6 motor mounts bolt holes.
Get upper ball joint spacers.
Disconnect front sway-bar.
Make sure front suspension travel is free & "loose"
grancuda is offline   Reply With Quote
Old 09-26-2013, 12:12 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Traction Advice
^ I have nothing to offer to the thread, but this was hilarious to me!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-26-2013, 02:21 AM   #12
PAWS 72
PAWS 72's Avatar
Re: Traction Advice
Originally Posted by bosshogg69 View Post
^ i have nothing to offer to the thread, but this was hilarious to me!
x2
PAWS 72 is offline   Reply With Quote
Old 09-26-2013, 05:50 AM   #13
deestrong71
Thumbs up Re: Traction Advice
Thanks for all the great info everybody
I think what will work best is the motor swap to the 307. LOL
I have the fuel tank in the rear over the axles now,
and Ill have to investigate on how to beef up the trailing arms, and find the correct adjustable shocks.
I was looking at the Mickey Thompson tire and this Nitto tire.
**Deestrong**
Old 09-26-2013, 07:47 AM   #14
Sharps40
Re: Traction Advice
Good golly, didn't think I'd get to use this twice in one week....
2 each 50 lb sacks of corn and sweetfeed in the back near the tailgate for all around traction heading to the bar. At closeing time yell, "I got 200 lbs of corn and sweetfeed, who's comeing home with me?"
I gaurentee, ye'll "hook up" every Sat night.
Sharps40 is offline   Reply With Quote
Old 09-26-2013, 09:03 AM   #15
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Traction Advice
I hope you arent running a 18 or 20" rim with low profile tires. You need the 15" rim with the 50series sidewall or those drag radials wont help much. Look at post #6... thats what you need.
Tom Vogel is offline   Reply With Quote
Old 09-26-2013, 02:27 PM   #16
deestrong71
Re: Traction Advice
LOL @ Sharps
I didnt even think about the Rim size yet, Ill definitely be looking at a 15inch wheel.
**Deestrong**
Old 10-01-2013, 08:36 PM   #17
deestrong71
Re: Traction Advice
Laying on my creeper, pondering on my traction issue, I realize that I only have 2" on space between the frame and the top of my Bump Stop. Not much room to change to a coil spring system and maintain my ride height.
What about a shorter Bump Stop and 1 less leaf in the leaf springs. I know i'm reaching for the lowest apple on the tree here.
**Deestrong**
Old 10-01-2013, 08:49 PM   #18
PanelDeland
Re: Traction Advice
I didn't realize it was a leaf truck.Try a set of "Slapper Bars' or the single bar for the front half of the spring(can't remember what it's called maybe cal tracs)..That should help stop axle wrap and give you a bit better traction.Keep in mind that your weak point right now is traction.When you find enough,your next weakest point will let you know where it is.
Old 10-01-2013, 09:11 PM   #19
mmiddle
mmiddle's Avatar
Re: Traction Advice
long slappy bars that go all the way to the spring-eyes and good shocks. Weld the axle tubes to the pumpkin. Adding a torque bar will help also.
Mark
Jesus is the Way!
Old 10-02-2013, 09:10 PM   #20
deestrong71
Re: Traction Advice
Thanks for the Advice, i ordered the Caltracs traction bar unit today. When it gets here I take pics of step by step installation and post em up.
**Deestrong**
Thread Tools
Display Modes
