Old 09-27-2013, 03:13 PM   #1
natecr
New to the forum 66 3/4 custom camper
Bought this truck a few weeks back. Pretty original, had stock hub caps down to owners manual and jack tools. Some type of early aded air conditioning, 327/3 on tree.. Thought i would share. Already dropped it 5 out back and 3.5 front with cut/ tj coils. Already bought a 72 front end to swap soon. Love these old trucks.
natecr is offline   Reply With Quote
Old 09-27-2013, 03:16 PM   #2
natecr
Re: New to the forum 66 3/4 custom camper
Current picture, after drop and wheels added.
Old 09-27-2013, 03:18 PM   #3
1963c-10
1963c-10's Avatar
Welcome and a great looking 66 you have there. Hang on to those OEM hubcaps...they are getting harder to find. The new stance looks great....keep us posted on the new project.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-27-2013, 03:24 PM   #4
natecr
Thanks man! I don't intend on getting rid of any factory parts on her. Especially how original shes is when i bought her.
66' custom camper 327/3spd 3.5/5 drop 17"s
2013 Subaru STI stage 1, exhaust, springs, sways ect
2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list.
1994 dodge cummins, straight piped, nv4500 swapped/built too much to list.
Old 09-27-2013, 05:21 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
What 63 C-10 said! This is a great forum with great members! Thanks for becoming a part of the crew! Love the truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-27-2013, 10:17 PM   #6
yelmer
Do you have the spid sheet from the glovebox door?
yelmer is offline   Reply With Quote
Old 09-28-2013, 01:06 AM   #7
19666Trucker
19666Trucker's Avatar
Posted via Mobile Device wow 66 custom camper down to same color if my was painted over it was Seattle Washington now in phx az, I cut my coils all round and 2" blocks in the back same rims too sweet truck.
19666Trucker is offline   Reply With Quote
Old 09-28-2013, 01:12 AM   #8
oem4me
Love 'em exactly like this picture. Sweeeet truck!
Old 09-28-2013, 02:41 AM   #9
natecr
Yes, and PVC emission ad on certificate Cali use.. And the build sheet was still in the seat!
Old 09-28-2013, 02:43 AM   #10
natecr
Nice. The tj coils are a nice drop and I cut 1.25 coils out of her. Gonna keep it original as possible but while still slamming it on the ground.
Old 09-28-2013, 03:01 AM   #11
jtrichard
not to be picky BUT it is a PCV valve (positive crankcase ventilation valve)...forever ..... PVC you buy at home depot and PCV you buy at napa just had to say it ... great truck
jtrichard is offline   Reply With Quote
Old 09-28-2013, 03:13 AM   #12
natecr
I know that and you know that but my "mobile device" was not in the loop. Thanks on the complement!
Old 09-28-2013, 09:06 AM   #13
yelmer
send pictures of the spid sheets thanks
Old 09-28-2013, 09:41 PM   #14
natecr
Old 09-28-2013, 09:42 PM   #15
natecr
Anyone seen this type of a/c unit before?
Old 09-28-2013, 09:43 PM   #16
natecr
Anyone know the the engine conversion option is all about?
Old 09-28-2013, 10:28 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Yup, one of the members has that same unit.
Old 10-02-2013, 12:37 AM   #18
19666Trucker
Do the side maker light s work as turn or running lights, that interior is clean. Blocks are good way to get it lower to. Easy to make.
Old 10-02-2013, 02:13 PM   #19
sodly
sodly's Avatar
I bet Yelmer would like to see that build sheet in a little higher resolution. I would, too!
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 01-11-2014, 12:36 AM   #20
19666Trucker
How's that custom camper doing
Old 01-11-2014, 01:03 AM   #21
LT1 Burb
LT1 Burb's Avatar
My sub had that AC unit in it when I bought it.
LT1 Burb is offline   Reply With Quote
Old 01-11-2014, 01:14 AM   #22
natecr
It's coming along. The bed is off for new wood. Upgraded to a Saginaw full synchro 3 speed trans. I now have restored set of rallies that are black and no trim ring. 12 bolt 5 lug 3.08 rear. And a 5 lug crossmember. Waiting on c notch and drop spindles and new ball joints and stuff to put it in. Thinking about taking the a c out
Old 01-11-2014, 12:26 PM   #23
LT1 Burb
LT1 Burb's Avatar
Love the look of this.
Old 05-26-2014, 05:22 AM   #24
natecr
Have made some headway.. 72 chevy 12 bolt 5 lug, cleaned up some rallies, cpp 5 in spring, notch, pan-hard bar, shocks, shock relocator, 2 in blocks, and poly tralling arm bushings. Camaro rear sway bar. Ford f250 rear flex brake line.. All new brake tubing, used 69-72 rear brake cables (only had to move the mount 1 inch and only 13$ at any auto part stores!) Did some neat adapting on this project. And fyi 3/4tons have double plated frames which make the c notch a big job! No rivet will hit out cause plate misalignment! any-who.. Heres some pics..
Old 05-26-2014, 05:23 AM   #25
natecr
Some parts
Thread Tools
Display Modes
