Old 09-30-2013, 02:29 PM   #1
Black70c10
Black70c10's Avatar
Horrible acceleration- timing, shift points, torque converter??
Hey guys,
I'm new to the forum. I recently took my 70 c10 to Dukes Speedmaster to to get the torque converter lock-up switch installed. They did great work and I was very pleased with them. But they couldn't really help me with my acceleration issue.
I am looking for a shop somewhere in Houston that can tune carbuerated engines and that may also have a dyno. I've got a very clean 350 with headers and a mild cam, but it runs unbeleivably slow. It has a rebuilt 700R4 trans with a 1800 RPM stall. However, it just doesn't have any get up and go because it's not running throughout the power band. For instance, say I'm cruising at 20 MPH and mash the throttle to the floor... it only drops down into 2nd gear and then it shifts to third waaaay sooner than it should.
I was told that my kickdown cable is set up correct, fully taught with WOT, so I'm wondering if this may be a timing issue of some kind? Or maybe the shift points need to be adjusted? The timing appears to be set ok, it idles great and it drives very well until it comes time to get on it. I've driven crummy old beat up 350's that had twice the acceleration that this thing has. With an electronic ignition, cam, headers, et.. this thing should be halfway quick..
Any recommendations would be greatly appreciated!
Black70c10 is offline   Reply With Quote
Old 09-30-2013, 03:22 PM   #2
geezer#99
geezer#99's Avatar
Re: Horrible acceleration- timing, shift points, torque converter??
Timing set OK!!
What's the initial timing set at?
What carb?
What intake?
What's the cam specs?
geezer#99 is online now   Reply With Quote
Old 09-30-2013, 03:40 PM   #3
Lee H
Lee H's Avatar
Welcome to the forum! Lot's of very knowledgeable folks here more than willing to help out. In addition to Gezzer's request, tell us able your distributor, have you verified the mechanical and vac advance are working?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-30-2013, 04:20 PM   #4
Longhorn 70
Longhorn 70's Avatar
Timing shouldn't affect 700R4 shift points. What happens when you pull it down to 2nd manually?
You may also want to read 700R4 TV cable adjustment procedure.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 09-30-2013, 06:23 PM   #5
Black70c10
Black70c10's Avatar
Appreciate all the responses. Unfortunately, the previous owner could not give me any of the cam specs. It has a Weiand 1546 intake manifold, a 650 cfm edelbrock carb (1806 series) and a pro-billet MSD distributor w/out vac advance. I just figured the timing was set ok because it runs and idles well. I checked it a while ago and it looks like it idles at 35 degrees... This seems a little high. Shouldn't the base timing be somewhere in the 12-15 degrees range?
Appreciate any help.
Old 09-30-2013, 06:35 PM   #6
Black70c10
Black70c10's Avatar
One other thing, I didn't have time to check and confirm that top dead center is in fact set correct, or that the marker falls on zero at TDC. I'll have to do this when I get back in town. But for now, assuming that it is marked correctly, any advice would be appreciated!
Old 09-30-2013, 06:48 PM   #7
geezer#99
geezer#99's Avatar
I was just thinking that. Confirm tdc and your timing marks. You might have a mismatched tab and balancer or a slipped balancer.
With your combo you might need up to 18* initial.
Also check to see if your carb is opening fully. With or without the tv cable hooked up.
Old 10-01-2013, 12:54 AM   #8
NVBUYER
Hello! You should definitely check you TV cable adjustment. While it may be taught the outer sleeve controls some line pressure from my understanding. Hopefully clinebarger can chime in and offer more on this.
NVBUYER is offline   Reply With Quote
Old 10-01-2013, 09:07 AM   #9
trac209
Your tv cable setting controls shift point and line pressure in the trans. Do not drive with a mis adjusted shift cable on a 700r4 or that tranny will not last very long. Look up cable adjustment procedure or take to somebody that knows what they are doing so it doesn't burn your trans up.
trac209 is offline   Reply With Quote
Old 10-01-2013, 04:16 PM   #10
cdowns
cdowns's Avatar
what rear end ratio?? tire size??
exactly what type of vehicle are you comparing this truck to ?? acceleration for a beat up old ragged out nova or comaro will b quite different than a 21/2 ton brick like these trucks are
Old 10-06-2013, 03:53 PM   #11
Black70c10
Black70c10's Avatar
@geezer- adjusted the timing down to around 20 degrees from 35 and it seems to run a little crisper. Ill continue to tweak the timing and carb to see wnat works best. Confirmed TDC too by the way. I think it still has something to do with the shift points, it's not staying in gear long enough before it shifts. It's really just a cruiser though, so I'm happy with it for now. Thanks for the help.
Old 10-06-2013, 03:57 PM   #12
Black70c10
Black70c10's Avatar
@trac and longhorn- thanks I appreciate the advice, will look into it
Old 10-06-2013, 04:56 PM   #13
BrianG
BrianG's Avatar
I'll second what cdowns asked. What gears and tire size? If your running 3.08's and large tires, your not going to have great low end acceleration and take off. If your comparing a setup like I just explained to a new Silverado, then it would surely seem very doggy.
BrianG is offline   Reply With Quote
Thread Tools
Display Modes
